      05-01-2020, 08:14 AM   #1
Taheemr
Drives: M6 GC
Gear engagement bump after cold start
Hello All
do any of you get a thump when engaging gear from an overnight cold start, I am getting varying degrees of an aggressive thud when either selecting reverse or 1st gear from a cold start from the P position.
at times its almost as the gearbox is going to expload its that agreesive and the car can lunge forward or backwards
Is this normal ?
Thanks
      05-01-2020, 11:56 AM   #2
Taheemr
Drives: M6 GC
it does seem to be less if i let the car idle for a few seconds from cold before selecting gear, I dont like letting the car idle when cold for obvious reasons.
I did have it checked but came back as no fault found, I just cant see this as being normal
      05-01-2020, 12:46 PM   #3
Dwaynos
Dwaynos's Avatar
What obvious reasons?
      05-01-2020, 02:25 PM   #4
Taheemr
Drives: M6 GC
get the car upto temp asap
      05-01-2020, 04:24 PM   #5
Dwaynos
Dwaynos's Avatar
You should let the car complete it's cold start cycle. Also, letting it idle for a "few seconds" certainly won't hurt it.
      05-04-2020, 03:44 AM   #6
OneExtra
OneExtra's Avatar
Drives: None
Agree, I let my car idle until the revs drop to normal then I start driving, maybe about 15 seconds ish
      05-04-2020, 06:25 AM   #7
J11SEK
J11SEK's Avatar
Drives: F10 M5 2015
Same, surely cold start is for oil circulation as well... so no load on engine until this is done! Like above 15secs or so....
      05-04-2020, 06:51 AM   #8
OneExtra
OneExtra's Avatar
Drives: None
That's also my thinking especially when its been sat for 2 weeks
      05-06-2020, 02:26 AM   #9
schrickm5
schrickm5's Avatar
Drives: 2013 M550d xdrive touring
The bump is normal, I had it in my 14 and also in the 15. Only happens once though after a cold start.
2015 M5 CP Blue
[SIGPIC]
Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 >
      05-07-2020, 05:32 AM   #10
Taheemr
Drives: M6 GC
Yes correct only from cold, I started on a few morning this week and the let the car idle for a few seconds the gear engagement thump was less intrusive but still present
      05-07-2020, 06:13 AM   #11
PoolCar
Drives: F10M5, 997 - 911
I don't know if this is 'normal' or not but I get no thump or
any noise at all when drive is selected.
Hope you can sort it out.
      05-07-2020, 01:28 PM   #12
Taheemr
Drives: M6 GC
had it checked out, Sytner found nothing wrong, at times its so harsh its as if the gearbox is going to shatter
      05-07-2020, 02:13 PM   #13
ianm5
Hi
My car is a 13 with c50k and the **gears** engage like butter, hot or cold. I don’t do any of the stuff described below on startup , I just drive away after seconds. What you describe is alarming. Are you sure it’s gears?
Is the thunk the normal pads ‘welding’ themselves to the disks? I used to leave a car on a seafront for 3 months. Pulling away needed 3000rpm. If I don’t drive for a while in the m5 there is a pad thunk. It would feel like a transmission thunk.
