01-22-2016, 02:43 PM | #1 |
Rep 3,305
Fully Built Custom Chevy 3100 - Bagged!
1NO expense spared on the build. Truck was brought down to metal for a complete respray. New color is a Rustoleum black. Essentially a Satin Black that is VERY durable & looks absolutely beautiful. I wash it with an "Eco Shine" spray product from a local socal shop & a microfiber, never taken it to a car wash. Truck: Small block 350 w/ turbo 350 trans Thumpr hydraulic big cam S-10 front end. Rear end of chassis custom built 22" chrome Racine wheels New tires Magnaflow exhaust Custom headers New U- joints New center carrier New Driveshaft Driveshaft balanced New steering column & shaft to box New idler arm New(added) zerk fittings in A-arms New battery cables New fuel pressure regulators & a phenolic spacer installed New fuel lines throughout New fuel filter Notch frame for fuel pump Front end lubed New custom mount for trans cooler New inner & outer seals on speedo bullet Entire truck rewired front to back in & out & converted to 12V New 120AMP Alternator Dome-light rewired & working Yellow foglights wired & working w/ their own switch to run as "daytime running lights" New gauges Gauges calibrated New electric fan & thermostat All 4 airbags replaced w/ new bags All airbag lines & fittings replaced New bumpstops made for all 4 wheels New custom brackets & added rear shocks New dimmer switch for high/low beams New door latching mechanisms on both doors (doors didn't latch) New glove box New rear view mirror ( didn't have one) Windshield wipers functional ( previously not) Cigarette lighter added / Aux power port All fluids in entire truck changed: Engine oil w/ new filter & drain plug gasket Trans oil w/ new filter & output seal New coolant Rear end seal & oil Interior: Stripped down cabin to metal for a complete overhaul Dash & cabin painted the burgundy deep red metallic you see in pics Custom pin-striping Custom switches built into the dash for the Airbags Dyna Mat throughout the cabin Brand new bench seat with diamond stitching New chrome steering column New Mooneyes 14" steering wheel Brand new floor carpet Brand new headliner Brand new door panels Doors aligned with new hinges Windows aligned & new control arms. Videos:
01-25-2016, 12:46 PM | #3 |
Rep 3,305
^^ thanks brotha!
03-22-2016, 08:39 PM | #4 |
Rep 3,305
bump, new pics added
07-20-2016, 02:56 PM | #5 |
Rep 3,305
HUGE price drop. NEED truck sold!
07-21-2016, 11:45 AM | #7 | |
Rep 3,305
08-09-2016, 06:48 PM | #8 |
Rep 3,305
price drop.
08-10-2016, 08:17 PM | #10 | |
Rep 3,305
