      02-26-2019, 11:32 PM   #67
Jasoneo5
Drives: 997 TTs, GS-F, RS6, M6 GC-sold
Originally Posted by boots View Post
lol thanks Jason. yes I always keep the car maintenance up to date. all fluids were changed as well as the clutch. im using a aftermarket trans pan. I've had 700hp w a aftermarket clutch and I'm back on a stock clutch. my car still looks minus a little seat scuff. I think the key is to ensure your oil is changed properly, your car kept clean and dont be afraid to drive it. mine drives just as good as the first day I bought it
Really great stuff! Have been seeing a lot of fear around injectors recently - did your 2013 injectors give you issues or require replacement? I'm a 2014 so not sure if that works to my favor or not
      02-27-2019, 06:10 AM   #68
boots
Curve Thrasher
boots's Avatar
623
I had to replace mine but it only was tune related. you should be fine. dont worry. these cars are very good. they only really mess up when you begin to change things.
Country run
      02-27-2019, 06:45 AM   #69
M6Bower
M6Bower's Avatar
10
Drives: 2013 M6 Coupe
I have 2013 m6 and I just replaced all my injectors. Pretty pricy but had to be done.
I have 73K kilometers on it with downpipe and tune installed maybe the past 20k kilometers.
Injectors were faulty which effected other parts of the car that needed to be changed.
      02-27-2019, 06:08 PM   #70
Jasoneo5
Well I'm on BM3 OTS Stg2 at 65k miles now - hoping to not run into injector issues.....
      02-27-2019, 08:35 PM   #71
YanoM5
Drives: 2018 Individual Nardo M5
Got her with 57K miles. I have 81K miles.
*Changed rear rotors and brakes at 70k miles. New tires as well.
*Did my own plugs at 73k miles. Got a DTM code after my Bootmod3 Stage 2 Tune. Injectors were bad though. I heard we should change them every 20-30k miles on our car.
*My right lower control arm is going bad. Making noises. Ordered the part. $450.
All in all for a German car at 80k miles, I feel it runs strong. I even have front mount intakes and this thing fires right up in 23 degree temps. After I change my control arm, I feel it can keep running strong. No signs of leaks or oil leaks under or over the car.
I’ll sell it trade it soon enough when the F90 prices come down. I need AWD.
      02-27-2019, 09:04 PM   #72
Jasoneo5
Damn, at what mileage did you change the injectors? Was there a symptom that lead to your decision to change them?
      02-27-2019, 10:01 PM   #73
RAFiK - BMWClubUAE
Drift Instructor @ BMW Club UAE
RAFiK - BMWClubUAE's Avatar
United Arab Emirates
310
Drives: BMW F10 M5
2013 BMW F10 M5  [10.00]
At 80,000 km my car went for a huge list of new parts that needed to be changed
- Engine mounts
- Transmission mount
- Front Rotors/Pads
- Rear Rotors/Pads
- Ignition Coils
- Injectors
- Spark Plugs
- Steering Pump
- Lower Arms
- Steering Links
- Rear Differential Bracket
- Rear Sub-frame
- Valve Seals
- Top Cover Gasket
- Headlight Washer
And some other parts that I cannot recall at the moment. Anyway, long story short, God bless Warranty and a good connection at the service center. I am almost driving a brand new car that will easily last for another 50,000 km without any issues.
F10 M5 - AlpineWhite/SakhirOrange[DCT](Current)
F16 X6 - SparklingStorm/CognacBlack (Current)
Follow me on Instagram (Click)
      02-28-2019, 02:47 AM   #74
schrickm5
schrickm5's Avatar
Drives: 2013 M550d xdrive touring
What are the normal Error Codes for Ignition Coils and Injectors, or does the car just cough and splutter?
2015 M5 CP Blue
[SIGPIC]
Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 >
      02-28-2019, 05:09 AM   #75
Who's on first
Who's on first's Avatar
Drives: A-10C
- Engine mounts
- Front Rotors/Pads
- Rear Rotors/Pads
- Ignition Coils
- Injectors
- Spark Plugs
- Steering Pump
- Lower Arms
- Steering Links
- Rear Sub-frame
- Valve Seals
- Top Cover Gasket
- Headlight Washer
That's nuts.
      02-28-2019, 08:59 PM   #76
isved
Drives: 2009 335i XDrive
What is the consensus on suspension refreshes on these cars?
My car has 60k miles and drives very well, all bushings look good, but I can't help but think that it would drive better with some things replaced.
Are there specific parts that should be looked into around 60k miles?
      03-01-2019, 02:52 PM   #77
Craze
Mines done around 65k miles and we checked everything
It was still perfect!
      03-01-2019, 04:01 PM   #78
33000 miles and feels tight as a Scout's noose.
      03-01-2019, 10:54 PM   #79
RAFiK - BMWClubUAE
310
Drives: BMW F10 M5
Almost anything related to ignition/fuel supply/air supply will result in Drivetrain Error.
Originally Posted by Who's on first View Post
That's nuts.
Don't forget that our climate is very harsh on the cars and we drive on high speeds everyday due to our stretched highways. Our speed limits on some roads are 85 mph (140 kph)
      03-04-2019, 01:01 PM   #80
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
- Engine mounts
- Front Rotors/Pads
- Rear Rotors/Pads
- Ignition Coils
- Injectors
- Spark Plugs
- Steering Pump
- Lower Arms
- Steering Links
- Rear Sub-frame
- Valve Seals
- Top Cover Gasket
- Headlight Washer
Maybe your car is never before you take in care. Just drive pedal to the metal.
Or driven more than you know...?
      03-04-2019, 11:49 PM   #81
RAFiK - BMWClubUAE
310
Drives: BMW F10 M5
Well the previous owner simply did NOT do anything except change engine oil for the past 4 years... This service was done a month after owning the car. So I restored it back to it's factory condition
      06-20-2019, 07:31 AM   #82
907E60M5
Drives: 06' BMW M5, 10' BMW 135i
Originally Posted by scottgps92 View Post
I actually just purchased that car! Unbelievable how clean and well taken care of it is. I was skeptical at first especially with the high mileage, but once I looked over it and tested it out it was literally flawless and drove amazing! The original owner took such good care of it and could tell he did not abuse it.
I have big plans for this one within the next year or two!
scottgps22 I believe i am looking at purchasing you car from a dealership and had a few questions. I sam the Meth lines and heat wrapped lines and after doing some digging and comparing mods and color codes i am almost positive it is your very car. If you don't mind messaging back that'd be great!
      06-21-2019, 08:02 AM   #83
Steve Fox
Drives: 2014 M5 CP
I am about to hit 100k miles
      06-21-2019, 02:56 PM   #84
tqbmw
Drives: 2013 F10 550
40k. Air condition condenser replaced and coolant lines twice. Nothing else. Car runs and looks new. It's a 2013 with manual
      06-22-2019, 04:47 AM   #85
roscopeeco
Drives: 2016 BMW M5
I don't understand how someone who owns an early model F10 can only drive it less than 20k miles in its life. That takes a lot of self discipline.
      06-23-2019, 02:57 AM   #86
Steve Fox
Drives: 2014 M5 CP
Its the perfect daily.
      06-23-2019, 05:05 AM   #87
boots
Curve Thrasher
boots's Avatar
623
sometimes w the tunes you would have to change a injector. I did but it was no biggie.
Country run
