12-31-2019, 05:05 PM | #1 |
Rep 1,397
First time using Bimmercode: SUCCESS!! (Things I've noticed)
Just wanted to share my experience with Bimmercode. Purchased the OBD2 dongle on Amazon and paid for the full version of the APP. Easy.
-I put a trickle charger on my car overnight and battery was at 100% -Left the trickle charger on the car and just turned on the "position1" without starting the car and left the driver door open. -Turned Airplane mode on my phone (you must do this to avoid any interruptions during the coding process from phone calls, text messages, etc.) -Opened the app and started coding away. -During the process, my dash often switched on and off and at times errors would light up the dash like a Christmas tree (it works itself out but it gave me a heart attack nonetheless.) -After I was done coding, I unpaired the dongle and the phone, removed the dongle, shut the car completely off, restarted it, and everything went back to normal. Odd things that happened: 1) The dash lit up like a Christmas tree with every error you can think of (no worries, this is a part of the coding process). 2) All of my radio settings went bye-bye. 3) I had a Driver Side Restraint System Malfunction light that was always on and was driving me nuts (caused by a detailer who steam cleaned my seats) and after the coding, the light went away. I am over the moon on how easy it is to code with just an app and a dongle and about 70 or so dollars invested. Unlike CARLY would have cost me hundreds and their ratings have tanked. Plus for some reason it got rid of that annoying SRS Light and code (I don't know how the heck that happened). I just coded all the easy stuff but now I can experiment at my own leisure. HIGHLY RECOMMENDED to those on the fence of getting this coding APP. |
01-03-2020, 07:15 AM | #3 |
Rep 38
Drives: 2016 M5 Competition
Similar experience with Bimmercode for me on my F10 comp. The previous owner had already turned on the memory feature for the auto start/stop which is fine. I disabled the active sound and few other things. It's been a good experience so far!
01-03-2020, 08:45 AM | #4 |
Rep 169
I have disabled active sound. Start/Stop to OFF and afew other things = Xmas start up greeting, because the mrs loved it haha!
I don't get any error codes on dash etc, my systems just shut down then start back up with no issues! Love it. I even tried coding the Active Sound to sound like an M3, it wasn't great though!
BMW F10 M5 Competition
Hyundai i30N Porsche 986 Boxster S |
01-03-2020, 10:21 AM | #5 |
Rep 1,397
Next things I want to code is:
-DVD in Motion (but I have the DVD player system with the screens in the headrest, need to find out if coding the main I-drive screen will affect the rear players) -Start/Stop Off -Some lighting bits Attached are pics for a member who had questions about the trickle charger I was using. |
NotSooFast79.00 |
01-03-2020, 10:40 AM | #6 |
Rep 1,397
I have the charger attached on the days that I do not drive the car because these cars are prone to electrical gremlins and other shenanigans when the batteries run low... the former owner did this as well...
01-03-2020, 11:44 AM | #7 |
Rep 279
Drives: 2021 M5 Comp, 2011 M3 E93
I also had a great experience using Bimmercode. I would recommend to anybody looking to do coding to their M5.
01-23-2020, 08:55 AM | #8 |
Rep 146
Which setting codes out ASD?
In the Demo mode, there's an option "Active Sound Design Deactivation" with only 2 choices. When connected to the car, that option is not there anymore. I can only go to Expert mode and lists all of the categories "Model Range, Engine, Audio Level, Power Class, Comp Paket, Country Variant, Construction Stage, UNBELEGT". Which to change to disable it? |
01-27-2020, 10:36 AM | #10 |
Rep 146
Yeah I bought the full version, but there was no easy on/off like I've seen posted by some others. However I did found it in expert mode:
Headunit HU_NBT 3000 HMI search for ASD ASD_SOUND_OFF Default is "not aktiv" change to "aktiv" and now it's off. Much better and not as droney (is that a word?) Last edited by texsn95; 01-27-2020 at 03:30 PM.. |
02-11-2020, 07:43 AM | #11 |
Rep 256
On both my old 2013 and current 2015 M5s the start/stop has always been set to off. I thought only the non-M cars had to have the button pressed with each use of the car, but the Ms kept the setting stored once the button was initially pressed. Curious about why some folks have to code this in.
Current:
2019 911 targa 4 | GT Silver Metallic 2019 X3 M40i | Glacier Silver Past: 2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi |
02-12-2020, 07:27 AM | #12 | |
Rep 170
02-26-2020, 03:57 PM | #13 |
Rep 385
I think it may not be necessary but it is satisfying to change the coding so that the start up state is "off" instead of the factory set "use state from last shutdown".
03-03-2020, 09:01 AM | #14 | |
Extruding Elements
513
Rep 539
Drives: 2016 BMW M5 Comp
Hi, BimmerCode will not help fixing this error, sorry. Kind regards / Schöne Grüße Stephan Gauch -- SG Software GmbH & Co. KG Im Nasswasen 10, 72379 Hechingen |
03-06-2020, 12:36 PM | #15 | |
Rep 1,397
Fast.F10512.50 |
03-06-2020, 12:46 PM | #16 |
Extruding Elements
513
Rep 539
I guess I shall order a trickle and buy the full version. Called my Sales Agent and he said "sure they can clear it for you, but they will charge you"...having the F10 for less than 1 month...ok, I see M Tax is real LOL.
2022 Yukon XL AT4
2016 BMW M5 2015 Ford F250 Super Duty 2006 BMW M5 |
03-08-2020, 03:57 PM | #17 |
Extruding Elements
513
Rep 539
Bingo...cleared my code
2022 Yukon XL AT4
08-29-2020, 03:45 PM | #19 | |
Rep 1
Passenger Restraint System
Thanks a ton! Judhi |
12-06-2020, 04:44 PM | #20 | ||
Real Car Enthusiast
288
Rep 2,082
01-07-2021, 01:36 PM | #22 |
Rep 146
