      09-19-2014, 12:06 AM   #1
avlnch
Drives: 2013 Individual M5
iPhone 6 Snap-In Cradle
You think BMW will come out with a new snap-in cradle to accommodate the slightly larger iPhone 6? Maybe they will have one for the 6 Plus as well?
I do remember the hassle it was just to obtain a cradle for the iP5. I don't know how BMW has handled new cradles for the latest phones in the past. But with the smart phone market share Apple has with it's iPhone, one would think BMW is already working on it? Apple releases dimension specs to certain companies way before the release date.
Hopefully they do. We can still hook the phone up via USB, but you loose out on the shark fin advantage and convenience.
      09-19-2014, 06:38 AM   #2
Knight Commander
For the 6 it will be a long wait. They haven't yet launched a dock for the Galaxy S5. I reckon it could be a 9-12 month wait.
As for the 6+ I don't think that will get a dock. They never did a dock for the Note.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      09-21-2014, 08:10 PM   #3
AlteBMW
AlteBMW's Avatar
Drives: '23 760ix; '23 X3; '23 MB wgn
The snap-in for the iPhone 5 came out around the same time the 5s was released. That means a year from now is not an unreasonable guess for a snap in for the 6. The only good news is that the 5 cradle may have required electronic changes because Apple shifted to the Lightning connector. The 6 is just a physical change so that it can fit.
      09-29-2014, 02:42 PM   #4
DietCokeOfEvil
DietCokeOfEvil's Avatar
11
It might have taken a year because of the input change (Lightening connector). Hopefully this time around, since it's just a form-factor change, it'll be a quicker design-to-manufacturing time.
      10-14-2014, 06:29 PM   #5
Knight Commander
@avlnch I just noticed that the iPhone 6 in case fits perfectly in the snap in connector cover which comes with the car. In principe you could modify the cover to drill a lightning cable through it and somehow fasten it in place to create a DIY dock. Given the size of the phone it won't move about since it perfectly wedges into that gap.
This guy did it with iPhone 5 but with 6 it should work better because of size.
http://www.bimmerfest.com/forums/sho...d.php?t=650352" rel="" target="_blank">http://<a href="http://www.bimmerfes...p?t=650352</a>
Would you have a sense on how to do this? The challenge is getting the connector firmly placed so it won't move.
      10-15-2014, 07:22 PM   #6
avlnch
http://www.bimmerfest.com/forums/sho...d.php?t=650352" rel="ugc" target="_blank">http://<a href="http://www.bimmerfes...p?t=650352</a>
Interesting... I'll have to look.
If you have a Dremel tool it shouldn't be too hard. You can drill one hole for the Lightning cable and it's connector housing to enter, then another hole right next to it that is just the size of the rubber cable portion. Insert cable into hole 1 then slide it across to secure into hole 2. That's one way at least.
      10-15-2014, 09:54 PM   #7
Knight Commander
The other guy used hot glue to fasten it tightly in place. I will try this soon.
      10-17-2014, 10:40 PM   #8
Knight Commander
I did it. iPhone 6 fits perfectly. In some ways it's better than the real thing because it doesn't have that stiff latch.
