      11-15-2018, 05:11 PM   #1
code600
Drives: E92
Will these rims fit?
Will this size rims fit for 2014 M5 Front 20x9 et 25 and rear 20x10.5 et 35?
      11-16-2018, 01:14 PM   #2
Ashley Schaifer BMW
Ashley Schaifer BMW's Avatar
Drives: 2015 M5 CP - Sakhir Orange
The biggest concern is the design of the wheel to fit the front calipers; and the provided specs can't tell you that, unfortunately. You'll either have to ensure someone else has successfully ran the same wheels/specs or measure the caliper clearance to be sure. With that said, those sizes and offsets work assuming it clears the front calipers.
      11-17-2018, 03:10 PM   #3
azndrunk74
Drives: Frozen Black F10 M5
You’ll need a 10mm or larger spacer in the rear.
      11-17-2018, 03:27 PM   #4
Nikolov
Pretty sure he should be good in the rear without a spacer.
      11-17-2018, 03:42 PM   #5
azndrunk74
Sure, but they will be sunken in. Best to buy wheels that fit well in the first place.
      11-17-2018, 04:20 PM   #6
Nikolov
No, they will actually stick out by 5.4mm. The stock 343 wheels are 10J ET34.
      11-17-2018, 04:33 PM   #7
azndrunk74
and most people run 12mm-15mm spacers on the stock rear wheels because they are naturally sunken in due to the weak offsets. personal preference if you want a more flush look or not.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
      11-17-2018, 04:39 PM   #8
Ashley Schaifer BMW
Typically, a rear with the following specs: 20x10.5 et 35 and Toyo R888r, one would not need a spacer. This is where there is a bit of variability and subjectivity--some tires fill up the space much better than others (i.e., Toyo r888r's, for example).Also, some people prefer form over function. If it were me, I'd have a higher offset so I can fit wider tires. At the end of the day, no one is wrong--just depends on what one is going for.
