      05-10-2019, 01:05 PM   #1
mcemce13
Drives: BMW M5 F10
DCT behavior
I am curious about my DCT behavior, and if it’s common or some issue with mine.
Many times when the car going down in speed slowly, i.e approaching a red light, or a curve, lets say I am in 3rd and I can feel like a small downshift happens and gear engages.
Its like the car was going in N and then the gear engages, I don’t see any change in the gear indicator, I am still in 3rd.
Its normal for the DCT to disengage the gear when you are not pushing the accelerator? And then reengage when it “believes” you will need it?
Would appreciate your input on this, thanks!
      05-10-2019, 01:09 PM   #2
GiddyAssassin
Drives: '14 BMW M5 CP
2014 BMW M5 CP  [10.00]
I'm new to the platform, but in the small amount of time I've had with my car I haven't noticed that.
      05-12-2019, 08:48 AM   #3
BeachM5nster
Drives: '14 M5
how many miles is on your car and what year is it.
your clutch is probably slipping and you'll just need to get a new clutch pack $3500
or you could have debris on the solenoids.
      05-12-2019, 09:05 AM   #4
mcemce13
Drives: BMW M5 F10
Its 2016 with low 11,000 miles. What is the debris on the solenoids you mention?
      05-12-2019, 04:32 PM   #5
BeachM5nster
Drives: '14 M5
you're good. dont sweat it. its probably just learning your driving style and previous owner probly drove like a granny
      05-12-2019, 04:43 PM   #6
BeachM5nster
Drives: '14 M5
ive heard ppl say they thought the dct could never figure out what gear they wahted to be in.. so i think that's just what youre experiencing
but my question is why do you have it in auto mode and not shifting manually with the paddles? because that's pretty much what I do at all times and I've never had those problems
the dct is an automated manual.. not an auto, not a manual..but theres a clutch
its like there's a little guy in there that runs the clutches for you..
have you noticed yet that when you're on an incline waiting to pull out into traffic and you let off of the brake it pops out of gear and goes into neutral and you roll backwards..
or have you noticed when you come to a complete stop in traffic at a red light and you're in first gear and you let off of the brake it just stays in place because it's in neutral .. it does this to save the clutch..
do u know about creep mode?
      05-13-2019, 12:45 AM   #7
Craze
Its not an automated manual
Dct is dct
      05-13-2019, 04:03 PM   #8
mcemce13
Drives: BMW M5 F10
Yes, I am aware of the behavior of the DCT on the inclines, when car stop, creep mode, etc and I am fine with that
In manual mode the issue doesn't happen. Just curious if its something I should worry about, or gearbox is about to explode, or its part of the normal behavior.
Another thing happens frequently at highway speeds is from 6 to 5 or 7 to 6, long "hesitation period". You push the accelerator ...and nothing...it takes like 2 secs until downshifts...and the car starts to accelerates. As you can imagine when you doing 160-180 Km/h, those 2 seconds seems like an eternity
      10-18-2020, 04:02 PM   #9
996c4smd
Drives: 2013 M5
Did you ever get to the bottom of this?
      10-19-2020, 02:32 AM   #10
Craze
What shift mode etc is it in?
The only time i notice the delay is when it hasnt preselected correctly next anticipated gear
The wire x5m is heaps better to drive around town and feel powerful on stock settings
The m5 need to change thr and gearbox settings to get any real acceleration
      10-19-2020, 12:42 PM   #11
996c4smd
Drives: 2013 M5
Happens for me in D1, D2, and Comfort & Sport. Not tried Sport+ but I think it'll happen then.
I took a video of the issue. Basically, I say "now" when I put my foot down most of the way, and you can see the car has selected 5th gear on the display immediately. However, it takes a 1 - 1.5s before it _really_ selects 5th and you see the revs climb and start accelerating. Throughout this time, my foot hasn't moved.
That 1-1.5s feels like an eternity when you're doing those sorts of speeds. Doesn't happen all the time, but seems to be quite consistent when you're doing 70+. Also happens from 6->4 at lower speeds.
Interestingly, if it goes from 7-6, it's fine, or 6-5. So it's almost like it's getting confused when it's changing gear on the same clutch. Doesn't happen at all in manual mode, I can manually shift as quick as I want and it always accelerates although it is a little harder to try and reproduce shifting manually.
      10-19-2020, 12:54 PM   #12
^ It's delaying the kickdown for a reason, 92k on the clock I see so has the DCT been serviced recently.
      10-19-2020, 12:56 PM   #13
996c4smd
Drives: 2013 M5
I don't think so. It's going into BMW tomorrow to be investigated, perhaps I'll ask them to do a DCT service whilst its in there.
Edit: this thread sounds similar, although I think the chap was manually shifting down and saw delays. Software update cured it.
https://www.6post.com/forums/showthread.php?t=1373945
      10-19-2020, 01:21 PM   #14
As you say a software update may cure it and I read there somewhere that the service guys may cancel out the preferred driving style mode temporarily making it sluggish.
      10-20-2020, 12:47 PM   #15
texsn95
Drives: 2014 Frozen Silver M5
LOL, you should drive an E60 SMG around town in "D" mode, it'll thunk and clunk until you think it's going to drop out of the bottom of the car.
1995 Mustang Cobra - 347 stroker
Dankrupt187.00
      10-21-2020, 04:08 AM   #16
Craze
The e60 smg is a fantastic transmission, its just misunderstood!
      11-06-2020, 02:42 PM   #17
996c4smd
Drives: 2013 M5
Software update didn't cure it, I'm not sure if it's normal, would need to drive another.
Sometimes, it gets confused, especially at motorway speeds, if I get it to repeatedly change gear in "D". So if I'm cruising in 7th then get it to change in 5th (with the delay), then let it naturally shift up into 6th, but at roughly the same time, press the accelerator enough to get it to change in 4th, it can delay and "bang" into 4th.
In manual mode, it's fine, but I can't change gears the same way it does in D.
      01-05-2021, 12:30 AM   #18
HustlerX5
Drives: 08 E93
Did you ever find a way to resolve this issue? My car (2015 F13) does the same thing, my friend is the previous owner and I found out he had the entire transmission assembly replaced under warranty for the same issue, and now here we are 6k miles later and it’s doing it again. My car only has 35k on the clock or so.
