10-18-2020, 10:31 AM | #1 |
Rep 402
Please help.
Need help. Driving on highway with 2014 M5. Car was spuddering when hitting throttle. Smoke started coming out out exhaust pipes. Pulled over on side of the road. No codes or alerts on car has come up. Smells like gas / oil in exhaust as well as inside the car. Car just hit 40k miles
10-18-2020, 10:41 AM | #2 | |
Rep 106
Speenybean91.50 Luckydacuz5.00 |
10-18-2020, 06:54 PM | #4 |
Rep 402
10-18-2020, 07:12 PM | #5 |
Rep 127
Well obviously no one can know for sure but does sound like an injector. On a positive note they extended the HPFP and injectors warranty to 10 year 100k miles on these so as long as you are not tuned you might just get it covered!
10-18-2020, 07:57 PM | #6 | ||
Rep 402
10-19-2020, 01:41 AM | #7 |
Rep 19,109
^ Have the engine oil changed also when they fix it as there will probably be gas in the oil.
Speenybean91.50 |
10-19-2020, 09:11 AM | #8 |
Rep 606
Sounds like it could be a stuck injector, as mentioned. I would NOT run the engine again until it's looked at. If a cylinder is filled with fuel now and you try to start it, you might bend a rod.
If it is an injector, what "M5theonlyone" stated is super important. Make sure the engine oil is changed! |
Speenybean91.50 |
10-19-2020, 09:13 AM | #9 | ||
Rep 402
10-19-2020, 10:23 AM | #10 |
Rep 19,109
^ I would say it's a good idea to change the plugs when the car is being worked on in that specific area.
Speenybean91.50 |
10-19-2020, 11:39 AM | #11 |
Rep 606
10-19-2020, 12:14 PM | #12 | |
Rep 402
10-19-2020, 12:18 PM | #13 | |||
Rep 402
The indy seems to think it's the fuel pump. Does this sound right? Could that cause the issues I explained |
10-19-2020, 12:22 PM | #14 |
Rep 606
It's certainly possible the high pressure pump has an issue? Without diagnosing the car in person we can only speculate. The tech sounds like they're on the right track, suspecting a fueling issue. You're going to have to trust their judgement.
Good luck |
10-19-2020, 12:30 PM | #15 |
Rep 19,109
HPFP failure would cause engine to shut down immediately with no fuel pressure I would have thought with no gas smell or black smoke, but as ''technician117'' has said let them burrow around there and test the pump if it's up to scratch.
Keep us informed. |
10-19-2020, 12:31 PM | #16 | |
Rep 402
M5Rick58412.50 |
10-19-2020, 12:48 PM | #17 | |
Rep 402
10-19-2020, 12:49 PM | #18 | ||
Rep 402
forgot to mention...on the day that this even happened, for the first time since owning my car I went through an automatic car wash. I have front mount intakes and I'm now wondering could the pressurized water from the car wash being sprayed into the front of my car have cause something like this to happen? Fml |
10-19-2020, 01:03 PM | #19 | |
Rep 19,109
[QUOTE=Speenybean;26816129]
10-19-2020, 01:09 PM | #20 | ||||
Rep 402
[QUOTE=M5theonlyone;26816188]
10-19-2020, 01:13 PM | #21 |
Rep 127
I personally go through auto carwashes with front mount intakes and haven't had an issue, I use oiled paper filters not the steel mesh kind though. have had no issues so far. pluss you would probably had a white puff of smoke.
10-19-2020, 01:14 PM | #22 |
Rep 19,109
[QUOTE=Speenybean;26816215][QUOTE=M5theonlyone;26816188]
Myself and many more on here wash their own cars with selected products,I wouldn't even dream of putting it through an auto wash. |
