05-19-2019, 12:50 PM | #1 |
Rep 69
Default driving settings without M1/M2 buttons
Is there any way to reset all the driving settings (i.e. dampers, gear change, steering weight etc.) to the default settings that are selected when the car is first started without using the M1 or M2 buttons?
I currently have M2 button set to the sportiest settings and and M1 set to D/efficiency/comfort/comfort but I'd really prefer to be able to use the M1 button for something else. |
05-19-2019, 06:21 PM | #3 |
Rep 4,209
No. The car starts in the lowest settings on purpose. Mainly because it allows the car's fluids to all warm before you have it in the hardest settings and abuse the engine.
05-20-2019, 05:55 AM | #4 |
Rep 473
Pressing M2 again should return all the settings back to normal. At least that's what it does on my car - you press it once to activate (unless you have MDM on or DSC off, then you need to press twice to confirm) and press again to deactivate, which resets everything to comfort.
94jedi839.50 |
05-20-2019, 01:13 PM | #5 | |
Rep 69
What I meant was that I would like, while I am driving, to be able to turn all the settings back to what they were when I start the car. If I have changed all the settings (e.g. by using the M1 or M2 button that I have programmed in advance) I want to be able to go back to the defaults without stopping the car and starting it again. |
05-20-2019, 06:47 PM | #6 | |
Rep 1,259
05-21-2019, 04:47 AM | #7 |
Rep 21,531
i just have M1 in easy mode and M2 in sprightly form and HUD rev counter comes on,in M1 hit it twice and rev counter comes on for that, just read the hand book.
05-21-2019, 11:26 AM | #8 | |
Rep 69
Thank you all for your help. |
