07-01-2018, 07:47 AM | #1 |
Rep 620
Data log
Hey guys, can someone tell me how my car is doing with the recent JB4 + BCM?
I recently changed from Stage 1 to the JB4 and right away noticed pretty big power gains from my butt dyno. Current Mods: Bms intake Bms charge pipe RPI CBE Jb4 with BCM and v3 Bluetooth.
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill | Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive |
07-01-2018, 07:55 AM | #2 | |
Rep 620
07-03-2018, 07:31 PM | #4 |
Rep 620
Which backend flash or where can I get a full tune?
07-04-2018, 10:06 AM | #6 |
Rep 620
If I get the bootmod3, how is that going to be a custom tune when my car isn't on a dyno?
mike5160.00 |
07-04-2018, 07:19 PM | #7 |
Rep 594
Trim maxed out
Which map you used ???? I prefer to use methanol kit To support your fueling And be safe with afr Afr too lean You have fueling issue Or you can tune your dme I recommend Dme Tuning company Best tuned and fastest car
Mohamed kamal elkasaby
07-05-2018, 05:01 PM | #8 | |
Rep 620
I'm scared to drive the car now haha.
07-05-2018, 05:21 PM | #9 |
Rep 620
I'm going to do some 3rd gear runs with WOT going from 2K-7Krpm, will post the logs after.
07-05-2018, 05:22 PM | #10 |
Rep 2,039
With a bootmod3 backend flash (stage 1 = cats, stage 2 = catless) you will be able to run Map 2 22psi without a problem. I would go this route before going custom.
So stage 1 or 2 off the shelf (" OTS ") and Map2 will be very strong, safer, and fun. |
07-05-2018, 05:25 PM | #11 | |
Rep 620
All my buddies are telling me to do a custom tune and that's the safest route because the tune is done for my car specifically. Thoughts?
07-05-2018, 07:14 PM | #12 | ||
Rep 594
Whats your fueling ? Afr too lean With map 1 should be ok But when your afr lean and trim maxed out Sure you have fueling issue
07-05-2018, 07:28 PM | #13 |
Rep 2,039
Custom is always better.
07-05-2018, 07:31 PM | #14 | |||
Rep 620
07-06-2018, 10:11 PM | #15 |
Rep 620
Got one run in before i ran out of street.
07-07-2018, 01:54 AM | #16 |
Rep 594
Can you add throttle, afr1, and afr2 , av ign ? In grahh ?
You car hit 22 psi on map 1 Your ignition 1 not good
07-07-2018, 01:59 AM | #17 | |
Rep 620
What do you mean by ignition 1 not good? Do I need to change plugs?
07-07-2018, 02:05 AM | #18 | |
Rep 594
Wheelpro@live.com
07-07-2018, 11:09 AM | #19 | ||
Rep 620
05-05-2020, 02:25 PM | #20 |
Rep 15
After reading this today 5/5/2020...I have questions
Did this car blow up from the 14.5 AFR and partial throttle pulls? Did he ever post pulls floored 100% 3k to 7k? Timing looks really low from partial throttle Praying it was tuned....
Exotic Cars & Coffee Louisville KY, 2011 M3 DCT 43K E93, 2014 X3 3.5i xdrive MHD Ceramic DP VRSF, Sold E93 335i, Sold, E90 335i, Sold M roadster, Sold 330i msport, Sold E60 08 V10 M5, Sold E90 335i, F10 BMW M5
05-08-2020, 01:52 AM | #21 |
Rep 620
Yea I went with openflash after all this and car is running strong still today.
05-08-2020, 05:09 PM | #22 |
Rep 15
Whew, great to hear! I was worried lol
