08-07-2018, 06:29 PM | #1 |
Rep 70
Gearshift Rod 2-R: Gear Fault Code
Getting a Gearshift Rod 2-R: Gear Fault Code and losing 2nd gear. Car will only shift out of 1st at about 4000 rpms and into 3rd. Car can not be shifted manually with the paddles. Car goes into drivetrain malfunction when this happens.
Also getting code speed sensor tg2: value not plausible Any one have this issue, and if so what’s the outcome
2014 M5
09-18-2018, 07:08 PM | #2 | |
Rep 594
still try , to find possible causes , paid alot , wast time, and still waiting too but I think , may be basket , or , mechatronic
Mohamed kamal elkasaby
09-19-2018, 01:18 AM | #3 | |
Rep 966
Is the DCT stock or do you have upgraded clutches ? I am working on trying to correct gear rod codes myself. Removed valve body and opened to clean. Got 3 codes down to 1 code. Previously trans would go into limp mode and would be fine after ignition cycle then went straight to only N is available. No gear selection possible. Now after removal, cleaning and re-install drive works but no reverse. |
10-06-2018, 10:20 PM | #4 | |
Rep 70
725whp/809wtq on 24psi -Stage 2 Pure Turbos -RPI GTM Exhaust -ER Catless Downpipes -SSP Clutch Kit -DSS Axles -K&N Drop In -CSF Charge AirCoolers -KW Suspension -BPC Rear Diff Mount Correct , same with mine if I shut car off and restart it I get all my gears back. Have got to the point yet where do it and just have N |
10-10-2018, 07:40 PM | #5 |
Rep 466
I would first recommend updating your transmissions firmware to the Sept.2016 version, which is the lastest update. This almost always fixes rod code issues. The firmware update allows for a lower clutch stack height to be accepted. The 2008-2016 (mid) models use a taller stack height (same clutch).
If the firmware update doesn't work, then the VB will need to be inspected for clutch and metallic debris. |
10-17-2018, 09:51 PM | #6 | |
Rep 966
On the 3rd disassembly on my current gear-rod shift diagnostic we took another look at the wear and measurement of the clutch discs and found the small discs being warped. It is hard to notice with just visual but by applying pressure to the stacked discs being removed we found that they were infact warped. This M6 is making more torque then HP which creates excessive wheel slip which can overheat the clutches and create this. We will be installing a fresh set of SSP clutches to see the result. |
Mcc420475.00 |
05-22-2019, 03:21 PM | #8 | ||
Frozen M5
40
Rep 204
This is per recommendation of SSP Kris, he knows these transmissions better than BMW does 😂
F10 Comp M5 - Frozen Cashmere Silver/Sakhir Orange | Vorsteiner Carbon Fiber Rear Diffuser |Vorsteiner Carbon Fiber Front Lip | Macht Schnell 12mm & 10mm Spacers | AMS Catless Downpipes | Meisterschaft GTC + LXR Pipe | BM3 Stage 2 |
M5Rick60061.00 |
05-22-2019, 04:42 PM | #9 |
Rep 608
After the update do you have to retune the dme's?
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
05-22-2019, 06:46 PM | #10 |
Rep 248
Sometimes yes because the dealer does a complete system update instead of just the DCT.
09-04-2023, 02:01 AM | #12 |
Rep 19,542
