      09-05-2018, 08:57 AM   #1
black_F10M5
black_F10M5's Avatar
289
Bimmercode - coding mirrors to fold on lock?
Hi guys, I've recently picked up the Bimmercode app and so far have only used it to turn off my ASD.
Is there somewhere in there that will cause the mirrors to fold when I lock the car? I've done some searching and haven't found it but I am still new to coding and probably missed it somewhere lol.
Any other "must-do's" in regards to coding through Bimmercode?
Thanks
      09-05-2018, 10:19 AM   #2
Lightfytr
Drives: 2017 750ix 2014 M5 Competition
I did all my coding with Carly. I believe they are similar in coding ability. I removed the warnings for nav, added video in motion, trunk close with remote, trunk close with footwell sensor, windows and sunroof close with remote, added turn signal in HUD, and some other small stuff. Good luck.
Ickdeep5719.50
      09-05-2018, 02:52 PM   #3
SapphireM5
SapphireM5's Avatar
711
There is coding through bimmercode to do the mirrors. I coded mine to fold in with the key fob once I hit lock and hold the button for a few sec. Also coded to have the windows and sunroof close and open with the key fob. I have to find the setting though for you.
      09-06-2018, 06:40 PM   #4
black_F10M5
289
thank you, that is exactly what I am looking for with the mirrors folding on lock. I will take a look this weekend to see if I can find it in bimmercode.
      09-06-2018, 06:43 PM   #5
SapphireM5
SapphireM5's Avatar
711
CAS / KOMFORTSCHLIESSUNG_FB = aktiv
CAS / KOMFORTSCHLIESSUNG_PA = aktiv
FRM / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
Also, if you don't want a delay in closing, you also need to code this:
CAS->3003 FH MASTER->KMFRT_SCHLIESSEN->Werte=00
      09-06-2018, 06:49 PM   #6
black_F10M5
289
Thanks so much. So I assume I need to do this in expert mode?
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S
      09-06-2018, 06:51 PM   #7
SapphireM5
SapphireM5's Avatar
711
Yes, expert mode. You set the value for the delay or how long you have to press the lock to fold the mirrors. If you want it as soon as you hit the lock, then put in wert 00. 1/4 second wert 02.
      09-06-2018, 07:00 PM   #8
black_F10M5
289
This is so helpful, thank you
      09-15-2018, 09:41 PM   #9
jamier2
Drives: 2016 M5
I did mine with Bimmercode, and was able to do it without going into expert mode. I still haven't even tried that part yet. I don't remember how I did it exactly but it was pretty easy.
I also tried to get the turn signals to show up on the heads up display but even though the Bimmercode said it was coded it still doesn't work for me. I guess I'll have to open up the expert mode to get that one to work.
2016 M5
      09-16-2018, 04:59 PM   #10
SapphireM5
SapphireM5's Avatar
711
When I did my turn signals for my HUD I think I had to change the settings in two different areas. Ill see if I can find it.
      09-16-2018, 05:11 PM   #11
SapphireM5
SapphireM5's Avatar
711
Here is the cheat sheet I used:
https://f10.m5post.com/forums/showthread.php?t=907307
      09-20-2018, 04:02 PM   #12
TLK
TLK's Avatar
112
I think the turn signals can only be seen in hud if you don't use M View. I always drive with M View enabled since I use the paddles full time in S3 mode. Unfortunately M View turns off almost everything that can show in the HUD...
      09-23-2018, 11:21 AM   #13
jamier2
Drives: 2016 M5
Thanks for that.
2016 M5
      09-23-2018, 11:23 AM   #14
jamier2
Drives: 2016 M5
Cool. I generally drive with the non M view, just have that set up for the M2 button where everything is at the max. Day to day I use the non-M HUD view. With the steering wheel position I like I can't see the turn signal display.
2016 M5
      05-05-2019, 02:03 PM   #15
BMW_driver_2008
BMW_driver_2008's Avatar
Drives: BMW M6
My mirrors were folding with a long press on the FOB after bimmercoding.
I then entered a wert of 00 in expert mode and they stopped folding.
I loaded the backup and they folded with a long press.
I am in a 2016 550i drive not an M5 but cannot figure out how to get the mirrors to fold with just a short press on the fob or the comfort access button.
      05-06-2019, 10:54 PM   #16
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
In bimmercode:
Front Electronic Module (FEM-01)
Scroll down to MIRRORS
Here you will find several options.
Good luck
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      01-11-2020, 06:02 PM   #17
NZ-M340ixDrive
New Zealand
27
Drives: 2020 M340i xDrive
This helped lots but my one touch with wing mirrors only works with the comfort access not the button.
Who knows how to code windows up with one touch
Thanks again
      01-17-2020, 12:43 PM   #18
texsn95
Drives: 2014 Frozen Silver M5
Going to pick up my CP 2014 M5 today, and downloaded bimmercode and ordered this adapter
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Question, can I run Inpa from my laptop using bluetooth, or do I have get a cable like this one to run PC programs?
https://www.amazon.com/OTKEFDI-Enet-.../dp/B07XND685R
Coming from an 06 I'm way behind the curve on the F10s.
