      04-16-2019, 06:37 PM   #1
MIM5
MIM5's Avatar
220
Drives: E92 335i
  [0.00]
How do I know if my clutches are slipping?
Just like the title. I’m tuned in stage 2 bm3 with downpipes and drop in intake. Tried doing a pull today in 4th at 80 and it feels like the engine free revs for a split second, then catches and goes. Not sure if it’s the tires losing traction, turbo lag, or a slipping clutch? Never got any clutch over heat errors or any of that. Car is 2014 dct car with 38k miles and was just tuned recently for about 300 miles now.
      04-16-2019, 08:14 PM   #2
Drives: Black M5
Your clutches are slipping. You will basically see an rpm rise when you give throttle and the car won't go anywhere for a second or so. Usually happens in the lower gears before the higher gears. And you can get slippage with as low as 600wtq sometimes, depending on if you are launching the car hard or not. These DCT's don't like a lot of torque. Time to pull the transmission and upgrade the clutches.
_BSMM5123.50
      04-16-2019, 08:31 PM   #3
MIM5
MIM5's Avatar
220
Drives: E92 335i
  [0.00]
I have to do some more testing because temps were at 45 degrees outside on summer tires. I’ve watched vids of the dct clutch slipping and it seems like their rpm stutters when it happens. When it was warmer here in MI last week I could nail it in 3rd and it would just hook. I’ve never launched the car and have always tried to be above 3500 rpm before going full throttle.
      04-19-2019, 08:47 AM   #4
Aceway
Drives: E82 135i / F25 28i
There's no doubt your clutch is slipping. My clutch immediately started slipping after 100 miles on stage 2 tune at 45k miles.
      05-04-2019, 07:28 AM   #5
silverfoxS65
silverfoxS65's Avatar
12
Drives: 2008 E90 M3
2014 BMW M5  [10.00]
Also give the BETA stage 2 OTS tune a try
It's got reduced tq in lower gears to help with slippage
I have same setup as you and I have 60k on my car and I haven't seen any evidence of slipping
2008 Silverstone/Fox Red M3 sedan - daily
2003 Space Grey Metallic E39 M5 - Sold
2014 Sakhir Orange F10 M5 - sold
