      08-15-2020, 04:21 PM   #1
SpaceShipS63
Drives: F10 BMW M5, E46 BMW M3
More Power on Stock Bottoms!! Currently Sitting at 720whp/775wtq 23psi Boost
I KNOW there are cars out here making more than 700whp on Stock bottoms. Any tuners you guys recommend that i can work with?i want o tweak my ignition timing and boost pressure.
Current Set Up:
SSP Spec R Clutch
Project Gamma Intakes
E40 mix DME Custom Map w/ Meth
Charge Pipes
Charge Coolers
Upgraded Thermostat
Toyo R88R 315
Catless DP
      08-16-2020, 05:55 PM   #2
TinTin888
TinTin888's Avatar
Drives: 2014 F10 M5
Hit up Matt @ HD Tunning or Mike @ BMP.
They are both located in California.
On curiosity note, what are your current whp and wtq ?
TinTin
MILL522.00
      08-17-2020, 11:21 AM   #3
SpaceShipS63
its posted in the title 720/775. Which i hear is ow for these mods
      08-17-2020, 11:27 AM   #4
SpaceShipS63
BUMP
      08-17-2020, 06:59 PM   #5
94jedi
Drives: 2009 e92 M3
There's one guy w/ an M6 making closer to 800 whp but I think he may have upgraded turbos. stock bottom end for sure though. Check w/ DME tuning as well. Those guys don't hold back on HP.
      08-18-2020, 05:46 AM   #6
F10CPROG
Drives: BMW F10 M5 Competition
Velocity Tuning in the UK. Pushed over 1000bhp on the stock bottom end...
Hyundai i30N
Porsche 986 Boxster S
94jedi829.00
      08-18-2020, 05:09 PM   #7
94jedi
Drives: 2009 e92 M3
Ah that's right. Tommy Munro. Forgot about him.
      08-22-2020, 03:41 AM   #8
A3ch
Drives: 16 X5 M, 14 BMW M5
For how long?
      08-24-2020, 10:37 AM   #9
SpeedProtocol
SpeedProtocol's Avatar
Drives: '14 F10 M5 - '21 F90 M5
It blew. seen the video. Injector went or something.
      09-02-2020, 08:17 AM   #10
Chauncey.Bishop
Big girls don't cry.
Chauncey.Bishop's Avatar
India
125
Drives: E46 M3
Stick with DME and ask for more boost. 23PSI on stock turbos is still within safe ranges for your setup.
      11-07-2020, 05:49 PM   #11
DHUBM5
Drives: 2014 BMW M5
I'm running 710 rwhp on the stock bottom end with my race gas tune from Gintani (VP110). I've been running it for over three years now (every now and then).
2014 BMW M5 Comp Singapore Grey Metallic
Modifications: Gintani tune (91 and VP110 (724 rwhp)), MSR intakes, Akrapovic EVO exhaust, HRE S101, Evolve Catless Downpipes, Michelin PS4S, Vorsteiner Rear Diffuser, RW Carbon front lip and rear spoiler, M Perf Alcantara Steering Wheel, IND paint matched front and rear reflectors, Rayno nano carbon ceramic tint (40%), Hardwired Escort 9500ix
      11-10-2020, 09:29 PM   #12
warpeacelove
Drives: 550i
Current Set Up:
SSP Spec R Clutch
Charge Pipes
Charge Coolers
Upgraded Thermostat
Toyo R88R 315
Catless DP
Does the charge pipe truly help or they just serving as a upgraded safety net for the fragile OEM chargepipes?
      11-10-2020, 11:21 PM   #13
induc916
Drives: 2014 M6
Or you can Hit up Matt @ Cedar Performance.
      11-11-2020, 03:09 AM   #14
Craze
Most people get charge pipes for meth
However i understand meth being injected there probably isnt optimum
Not sure what other solution is available
      11-30-2020, 12:21 PM   #15
eritF30
Drives: 340i xdrive
Get the CSF charge coolers,they inject at the bottom right before the throttle bodies,a much better area to inject methanol.
