Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > M5 versus...
      03-31-2017, 01:50 PM   #1
ARC550
2014 F10 M5 (NON COMP)
100% Bone stock
93 Pump
50Degrees
Atco raceway
MT ET street tires
Comp Rims
11.5 at 123 MPH - BONE STOCK - Record
11.2 at 128 MPH - BMS Stage 1 piggyback - Record
People thought I was Full Bolt on lol. What people don't understand is these cars out the box are quick! People just don't know how to drive!
I could not use any higher map or boost as the stock clutch just could not handle it from a dig and kept overheating.
patb2393.00
      03-31-2017, 02:19 PM   #2
HXS
Licensed Drug Dealer
HXS's Avatar
Nice. You probably would get a quicker run with 343M's
      03-31-2017, 02:31 PM   #3
RaTeD ///M
Drives: 2K13 M5
Originally Posted by ARC550 View Post
2014 F10 M5
100% Bone stock
93 Pump
50Degrees
Atco raceway
MT ET street tires
Comp Rims
Congrats! That's moving! I'm assuming yours is a CP and your a DCT?
22 BMW M5 CS on order for August Production
20 BMW M5 Competition stage 1.5....
09 Zenith R GTR CP 4.4 Stroked CP tuned.....
      03-31-2017, 02:48 PM   #4
ARC550
2014 F10 M5
100% Bone stock
93 Pump
50Degrees
Atco raceway
MT ET street tires
Comp Rims
Non comp. standard M5 with DCT
Car dynoed healthy at 555whp stock
patb2393.00
      03-31-2017, 03:10 PM   #5
Advantage
Drives: 2019 BMW M5 F90 Competition
Nice results. Did you engage launch control?
      03-31-2017, 03:52 PM   #6
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Nice - it's the Mickey's!!
ARC550446.00
imyopusha195.50
      03-31-2017, 08:51 PM   #7
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
555 WHP? You know this is translated to over 620 HP at crank right?
It's a little too high for a stock car ....
gmd2003
imyopusha195.50
      04-01-2017, 02:44 AM   #8
Dandadda
Dandadda's Avatar
Drives: 2014 M5 COMP PACKAGE
What he said! ☝🏾☝🏾
      04-01-2017, 06:27 AM   #9
TrevorM3
Drives: 6.3 AMG
gmd2003
all of these cars are understated from factory. Even the m3,s and m4's.
dyno your m4, i bet you make more than you think...
and fwiw, i dyno'd 550 with just a dp, and i have cp. so figure i'd be at about 540ish w/o the dp.
still translating to over the "575" crank figure.
      04-01-2017, 02:01 PM   #10
ARC550
gmd2003
540-560who is very common for these cars on a dynojet.
Also, the NON-COMP cars tend to Dyno higher then comp cars as odd as that is.
The car is BONE stock straight out of service.
The only difference between my time and everyone else is I actually used Drag tires and was able to not spin from the dig.
Name one person who has tested a stock car this way?... Nobody. Their goes your answer.
As for Dyno #s.. if you haven't dynoed your car on dynojet or seen over 100+ dynos of M5/6 then please don't comment on "to high" because this is standard.
The cars are simply under rated from factory just like he M3/4 which Dyno 400-420who and are rated 416 crank lol
      04-01-2017, 02:01 PM   #11
ARC550
That's exactly it! People don't understand this is what the car is actually capable of with right tires lol.
People thought I was FBO ahahahaha
I think you and I are the only ones who can actually drive these cars lol
patb2393.00
      04-01-2017, 02:02 PM   #12
ARC550
gmd2003
540-560 Dyno and the numbers will vary depending on Dyno jet, correction factors, weathers and quality gas so their you go. 540-560 is very common.
      04-01-2017, 03:23 PM   #13
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Curious why. Because they are lighter? They are more narrow so less tire.
imyopusha195.50
      04-01-2017, 08:07 PM   #14
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I do agree with you about the fact these cars are underrated. In fact I'm the one always argued with many members in last 3-4 years about the actual power these cars make and that's why I mentioned @[gmd2003] (contact:162595) but 555 HP is a little high. I believe 520-230 HP is what we expect ; I'm not arguing for extra 25 HP however it means something about 30HP more on crank... Dinan measured 525 HP on wheels...Even IND measured 527 HP 3 years ago...I leave this link here as a record
http://www.bmwblog.com/2012/09/10/dy...ated-527-rwhp/
      04-01-2017, 08:07 PM   #15
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
REALLY?
      04-01-2017, 08:21 PM   #16
1cleanm6
1cleanm6's Avatar
Drives: M5 comp/Range/i3S
Wow 5mph trap diff with just a burger motor stage 1 pnp?
      04-01-2017, 08:39 PM   #17
patb23
patb23's Avatar
Drives: '14 M5 CP & '62 corvette
2014 BMW M5  [10.00]
1962 Corvette  [10.00]
100% Bone stock
93 Pump
50Degrees
Atco raceway
MT ET street tires
Comp Rims
Very nice. You got my time beat barely. But I did my 11.59 run with reg street tires.
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors
1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i)
ARC550446.00
      04-01-2017, 08:53 PM   #18
allmotor_2000
1087
Honestly the car can run a 10.9 @ 132 with just flash, meth and JB4+BCM.
Clutches will eventually give tho!
      04-01-2017, 08:57 PM   #19
ARC550
100% Bone stock
93 Pump
50Degrees
Atco raceway
MT ET street tires
Comp Rims
Amazing! Great to hear someone else has similar time!
patb2393.00
      04-01-2017, 09:02 PM   #20
ARC550
Two Dyno sessions don't mean squat. I have watched and witness over 100+ M5/6 Dyno and they are all within a 5% variance.
How about reach out and talk to tuners who actually tune the car before and after. They will tell you numbers Stock vs Tuned.
For the record I dynoed 548WHP stock.
      04-02-2017, 01:37 AM   #21
HXS
HXS's Avatar
Yes, 343M's are forged, while the 601M's are cast.
They're the same specs, just as long as they're for the same car. M5 widths are 9 and 10, while M6 widths are 9.5 and 10.5 (for both 343M and 601M).
      04-02-2017, 06:18 AM   #22
TrevorM3
Drives: 6.3 AMG
REALLY?
according to post 7, you have no idea.
keep it moving
ARC550446.00
