      12-04-2018, 09:33 PM   #1
Frouss
Drives: Sedan
Dell Optiplex 390 Upgrade: HELP NEEDED
I am trying to upgrade a Dell Optiplex 390 and have a few questions:
The model is the i5-2400 with 8gb of RAM and 500gb HDD.
1.) Does the stock mobo support 120mm fans?
2.) Can I use a GTX 1060 with the stock mobo?
3.) Would the GTX 1060 warrant purchasing a higher watt power supply?
Thanks for your help.
      12-07-2018, 04:30 PM   #2
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
You'll have to share what form factor the 390 is.
      12-09-2018, 12:39 PM   #3
Turkish Pickle
Drives: '21 330i xDrive
If it's the slimline, most you can do is a GTX1050Ti/RX560 low profile, probably you can do that on the stock psu but we'd need more details for that. If it's the bigger one you can fit a 1060, but you'll most likely need a new PSU. As far as your fan question do elaborate, do you want a quieter cpu cooler?
And honestly, I'd say before doing anything get a SSD. that alone will be the most useful investment you'll be making on a 7 year old computer
P111572.00
