      03-08-2019, 09:06 AM   #1
kubax86
kubax86's Avatar
Drives: M2
EDC Code out M5 F10 Issue
Hello,
I installed KW suspension and I want to code out EDC.
I've done following:
removed S223, then VO CODE:
ICM,DSC,HU_NBT,KOMBI.
Then I read faults with ISTA+ and I saw there are a lot of fault codes in almost every ECU - every code was about "...EDC transmitter is missing/message missing"
Anyone has idea how to successfully code out EDC from M5 F10?
Maybe I have to code every single ECU with removed 223 from FA?
Thanks for help
      03-13-2019, 10:11 PM   #2
TLK
TLK's Avatar
112
I hope to install KW V3 and do this also within a week or so.
Using TokenMaster's NCD tool to see what NCD's must be coded to ADD the EDC feature, I get only 3 modules: ICMQL, HU_NBT, and KOMBI L6 BO. The tool doesn't seem to be able to tell you what coding is necessary to remove a feature but this pretty much should say what parameters must be changed.
Try VO coding the ICMQL and see if that takes care of the problem.
      03-15-2019, 03:56 PM   #3
TLK
TLK's Avatar
112
Sorry I thought icm and icmql were different ecus
You might have to vo code all if you don't know which others need to code.
This post suggests that esys will skip ecus that don't have any changes.
https://f30.bimmerpost.com/forums/sh....php?t=1463221
      03-18-2019, 09:48 PM   #4
TLK
TLK's Avatar
112
Posts for F80 cars suggest that you must unplug the VDC (EDC) module. I believe it is located behind the front seat right-side kick panel.
      03-18-2019, 11:25 PM   #5
88tuning.id
88tuning.id's Avatar
Indonesia
39
Drives: E39 520i Msport
Have you tried plugging out the vdc module as suggested above?
Instagram: @tafikhulafaa & @88tuning.id
      04-22-2019, 03:41 AM   #6
Fyourticket
Fyourticket
Any update to this?
      05-02-2019, 11:34 AM   #7
Chauncey.Bishop
Big girls don't cry.
Chauncey.Bishop's Avatar
India
125
Drives: E46 M3
Originally Posted by Fyourticket View Post
Any update to this?
Same question here.
      05-03-2019, 03:16 PM   #8
TLK
TLK's Avatar
112
Most threads about doing this on the F10 M5 end this way, with no confirmation of a coding solution.
I had my KW V3s installed last week at Edge Motorworks in Mountain View. They installed the resistors from the KW EDC delete kit.
