      04-30-2019, 10:18 AM   #1
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
2007 BMW 335i  [0.00]
Exhaust reduces from 3" to 2.5" - Power loss?
Recently had an exhaust shop do a custom muffler bypass ($180 vs $1200 for a Turner/Soul) I'm very happy with the sound and from what I can tell it sounds identical to the name brand deletes for 1/8th the price.
However, The shop that fabbed this used a 3" to 2.5" reducer at the very end to fit 2.5" tip inlets... At first I didn't mind but now that I've had time to think about it and look at other peoples set up with full 3" to tips it has me wondering.
Does this 3" to 2.5" reduction at the very end of the exhaust cause any lost power?
Even if it doesn't I might just go back and have it replaced with 3" pipe because I'm OCD and want a full 3" exhaust - which also means I'll have to return the 2.5" tips for 3".
      04-30-2019, 10:47 AM   #2
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
It shouldn't cause any power loss. The problem some owners have for power lose with muffler delete is their vacuum lines are plugged correctly.
Got some pics or video? I just got my muffler tips and hopefully going in next week for muffler delete as well.
_BSMM5123.50
      04-30-2019, 03:13 PM   #3
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
I'll take some videos and upload them once I get the tips in. They're supposed to get in tonight...
I've been rocking the single 2.5" pipes sticking out the back since last Wednesday. Looks super ghetto right now.
I made sure the vacuum lines were plugged. They weren't originally and I noticed a large drop in power until I capped them.
Ickdeep5718.50
      04-30-2019, 03:17 PM   #4
GiddyAssassin
Drives: '14 BMW M5 CP
2014 BMW M5 CP  [10.00]
Interesting... how far back does it neck down to 2.5? I don't know this platform particularly well yet (still new to it), but in most turbo cars it makes a difference from 2.5" to 3".
      04-30-2019, 03:19 PM   #5
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
I'd say everything behind the rear axle gets necked down to 2.5"... Quite a bit.
I'm probably going to end up welding back in 3" pipe. Power loss or not, it just doesn't really look right.
      04-30-2019, 08:53 PM   #6
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Should be negligible... how much power are you pushing?
Ickdeep5718.50
_BSMM5123.50
      05-01-2019, 05:41 AM   #7
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Unless you are pushing over 8-900 whp won't make a difference.
Ickdeep5718.50
_BSMM5123.50
      05-01-2019, 02:15 PM   #8
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
I'm stock right now, plan on going catless dp + stage 1 within the next few months. Waiting to get some oil analysis before I wreck my feeble rod bearings
      05-03-2019, 05:46 PM   #9
allmotor_2000
1087
It wont' matter at all...
      05-04-2019, 03:02 PM   #10
Dwaynos
Dwaynos's Avatar
Tuning the car will not wear your rod bearings any faster. An oil analysis may not show any rod bearing issues even if you have.
      05-06-2019, 10:54 AM   #11
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
Well.. theres some good news and bad news in that I guess lol.
      05-06-2019, 10:57 AM   #12
Dwaynos
Dwaynos's Avatar
Don't worry about them. I'll be changing mine in month or so and pics will be up on here. You can then judge if they are bad or not.
On a better note, did you get your downpipes fitted?
      05-07-2019, 08:55 AM   #13
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
Started the removal last night and then realized I didn't have the right O2 sensor socket... so had to put it back together... Looks like it may be this weekend before I get to it now :/
      05-28-2019, 10:12 AM   #14
M335
M335's Avatar
47
Drives: E90 n55 IG@FrozenF10
I wouldn’t stress to much about that because all M5,s already have that bottle neck on downpipes from 3” to 2.5” when it meets exhaust
      05-31-2019, 02:27 PM   #15
BB6
Drives: M3 G80
When you say plugged correctly what do you mean? I plan on muffler delete and would like to make sure I'm doing it right
G80 M3 - Just getting started
      05-31-2019, 02:33 PM   #16
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
So each side there is a vacuum line you'll see that the car uses to control the valves within the mufflers. When you take off the mufflers, just make sure to plug them up with something so that it doesn't leak. Owners have reported power loss and its often that the vacuum line wasn't secured.
      05-31-2019, 03:10 PM   #17
BB6
Drives: M3 G80
So a plastic golf tee and duct tape, HaHa
