06-03-2019, 02:09 PM | #1 |
Rep 1,847
Headlight Washers - MOT
Just read that when you have an MOT they will test the headlight washers to make sure they are working.
If like me you have coded them not to work as it sprays fluid all over the bonnet as well as the headlamps which annoys me then when its MOT time don't forget to un-code them. |
06-04-2019, 12:41 PM | #2 |
Rep 69
I don't even have any. I presume that they were an option which is dohbly surprising. Firstly, who'd pay extra for them and secondly, something as trivial as headlight washers should be standard.
Out of interest, why didn't you just not press the button rather than coding them not to work? |
06-04-2019, 03:29 PM | #6 |
Rep 948
To my knowledge any car that has xenon headlights fitted as standard will also be fitted with headlamp washers, that's the law. Unless your m5 has halogen headlights, which I highly doubt, then it certainly has headlight washers.
06-05-2019, 12:13 AM | #8 |
Rep 69
Mine certainly doesn't. I noticed the blanking plates just below the headlights and had specifically wondered whether some M5s had headlight washers. Unless they are super trick retractable headlight washers, mine doesn't have any and it's a standard UK RHD car.
06-05-2019, 12:18 AM | #9 |
Rep 69
I presume from this that they work at the same time as the windscreen washers. I used to own a STI which had headlight washers but there was a separate button. I assumed (apparently wrongly) that the M5 was the same.
06-05-2019, 02:11 AM | #10 |
Rep 948
They are indeed retractable. They work every so many windscreen washes with the headlights on.
06-05-2019, 02:25 AM | #11 |
Rep 19,521
Also wish that there was a separate button for h/lamp washers,damn Bm lumber you with this delayed system that comes on without you knowing and splatters your bonnet
06-05-2019, 03:23 AM | #12 |
Rep 1,847
Hence why I coded them off, it annoys me when it puts a mist of soapy water all over the bonnet.
06-05-2019, 03:24 AM | #13 | |
Rep 1,847
As has been said they are retractable |
06-05-2019, 08:40 AM | #15 |
Rep 69
