      10-07-2018, 08:21 AM   #1
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
B&O bass cutting out
I just picked up my 2013 M5. During the 12 hour drive home, I was able to learn most of the "electronics". One of the things I noticed after a while is that although the sound quality of the radio was good, the bass would go out. Then randomly it would come back on. At first I thought maybe it had something to do with the reception on the radio but when I was in areas I knew the reception was good and it still had no bass, I knew something was up. Anyone experience this? Sounds like an amp problem? Where is the amp located? I wonder if someone messed with it before and the connection is just loose? Probably wishful thinking.
Any input appreciated!
      10-10-2018, 05:36 AM   #2
DL7
It is to the left side of the trunk under the carpet. See below which will show you.
https://f10.m5post.com/forums/showthread.php?t=983411
      10-10-2018, 08:23 AM   #3
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Thanks, I'll check it out. I'm pretty sure the ASD is turned off in my car, so maybe if they went the "unplug" route rather than coding, they partly disconnected the amp on accident. I'm assuming the amp is the large module underneath the ASD module.
      10-10-2018, 08:28 PM   #4
DL7
Yes, I believe so. You can find used b&o amps online. New ones are expensive.
      10-11-2018, 09:21 AM   #5
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
I did a quick search yesterday. Looks like I can get a used one for around $900. I'll do some diagnostics first though to confirm it is indeed the amp.
Thanks for the help so far.
      02-05-2019, 11:59 AM   #6
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
I forgot to update my thread. The amp was indeed bad. I bought a used one on eBay when there was a 15% off coupon.
I wonder if there is anyone out there that can refurbish them? Quite a costly piece of hardware to go bad. Mine otherwise was in good condition physically with only the bass aspect failing on it.
