      10-24-2018, 04:14 PM   #1
msq123
Drives: BMW M5 F10 2014
Audio upgrade - sufficient power?
Straight of the bat, apologies for the long post…
I have some noob questions about the capability of OEM battery and alternator to support my audio set up. I will try and break down what I have and how much I think every part consumes and my calculation for experts here to review.
I have BMW M5 F10 running 676 hi fi system with following changes:
a) stock amp driving rear 2 speakers only so I believe it is only drawing 25x2w (am I right in thinking if I am not using any other channel there is no more power usage?)
b) Audison Bit 10 connecting the above amp with my 2 aftermarket amps. I am not sure about power usage of this processor?
c) JLAudio XD400/4 v2 amp (75w x4 @4 ohms) driving door speakers (Focal K2 10cm) and Focal iFBMW v2 sub
d) Hertz HCP-1D monk amp (700w @2 ohm and 380w @4 ohm driving Hertz HX250 sub (400 watts). I was thinking of running this at 2 ohm, dialed down for lower power sub but I am concerned if 700w is too much for the car’s electrical system to handle. I will use 380w below in my calcs
Stock amp - 25 x 2 = 50w
Multi channnel amp - 75 x 4 = 300w
Mono sub amp - 380w
Total = 730 watts
Account for 30% inefficiency gives me power draw of 1043 watts (730/0.7)
Using 13 voltage to get to amp hour - 1043/13 = 80Ah (this is peak volume draw)
or worst case scenario of 12v = 1043/12 = 87Ah
So, my question is regarding the combined output of car’s alternator and battery. I am not entirely sure but from what I found on the internet alternator is 210Ah and battery is 95Ah.
When the car is up and running I understand that up to 60% of alternator output could be used by the car so I am left with 40%, i.e., 84Ah plus battery’s powe, therefore, I think I should be fine with the set up.
1. Could anyone familiar with car’s power management system have a look and check if my calculations are right and I can proceed with this set up without any risk to any component due to insufficient power?
2. Am I right in running my mono amp at 4ohm instead of 2ohm thereby saving about 320w (or 450w accounting for inefficiency). I don’t think I have enough power to run at 2 ohms and I should not be using battery when the car is running. Alternator should suffice my needs in most cases without drawing power from the battery.
Thanks
      10-28-2018, 02:22 AM   #2
boots
Curve Thrasher
boots's Avatar
623
wish I had the answer for you but I don't. hopefully someone here has done a upgrade.
Country run
      10-30-2018, 01:23 PM   #3
msq123
Found some answers on another forum that I would like to share in case anyone looking for something similar.
Basically, I should be able to run my amp @ 2ohms which is 700w without adding new battery or capacitor or any change to power delivery system.
In reality it's more like 550w at 1% THD and 700w at 10% THD. no one wants to hear musics at high distortion levels of 10% for long. This is all marketing bullshit to quote unusable power or with high distortion.
The numbers I used were with the assumption that I will be running the amps at 100% capacity which I am told will never happen for mids and tweeters. They will hardly draw 15% or the rated 75w power.
Subs use the most power but again, 550w or 750w only happens at 20hz frequency which is rare and at full volume. I plan to use crossovers to define ranges for various speakers so I will probably looking at 50% power capacity usage for the sub at most. And lower for underseat subs which I am running through JLAudio at 75w per channel.
Initially, the whole calc and frequency was very daunting but the article in the link below helped me understand how much power speakers will require from the amp at various frequencies.
https://www.audiofrog.com/community/...get-150-watts/
I hope someone finds this useful. Cheers
