04-11-2018, 03:11 PM | #2 |
Rep 5,231
KW HAS
04-16-2018, 10:53 PM | #4 | |
Rep 966
But the minimal drop springs are Eibach I think.. |
04-17-2018, 11:02 AM | #5 |
Rep 657
Eibach. Currently mine is only lowered at the front and look about right. I am going to do rears jut not got round to it. Eibach are progressive rate so very comfy but really stiffen up when push
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S |
04-21-2018, 10:17 PM | #8 | |
Rep 5,231
05-08-2018, 04:28 PM | #9 |
Rep 294
I run AC Schnitzer lowering springs....
07-03-2018, 06:26 AM | #11 | |
Rep 3
So is Eibach a good choice? Thank for the input. |
09-29-2018, 07:52 PM | #12 | |
Rep 74
Currently mine has competition package... rear about right...front is kinda have big gap... |
12-10-2018, 10:07 AM | #13 |
Rep 201
guys my mechanic is having issues installing the eibach springs. He says he took the struts to get them pressed to remove the springs so that he can install the new ones. He went to 3 places and no one can press the struts because it has the magnetic sensor and the wire on top that no one seems to be able to open? Isnt this supposed to be take off the springs and just replace them with the eibachs and the car will still work with the efficient, sport and sport plus suspension settings?
12-10-2018, 10:09 AM | #14 |
Rep 657
The wire on top pulls out. You should be left with a hole where the wire plugs in. Tell him to pull straight up and the wire will pop out
540i
12-10-2018, 10:11 AM | #15 |
Rep 201
just to add the mechanic is saying that the only way to remove the springs from the strut is to cut the sensor as the sensor is in the way of the bolts, did you all have to do that or is there a guide you followed?
12-10-2018, 10:17 AM | #16 |
Rep 657
time for a new mechanic. DONT CUT THE WIRE!!
540i
12-10-2018, 10:25 AM | #17 |
Rep 201
This is what he sent me. and he just said that the sensor is in the way to remove the bolts that holds the strut, the place he took the struts to be compressed won't compressed them because of that.
12-10-2018, 11:46 AM | #18 |
Rep 657
tell him to pull the wire off under that black cap. Pull straight up. easy job
540i
12-10-2018, 12:01 PM | #19 | |
Rep 201
I just want to be sure last thing i want to do is screw up the EDC. I have spent the last 2 hours looking this up and there is really no one indicating how other than yourself and the article above which has no photos unfortunately. I appreciate you responding so promptly tho. |
12-10-2018, 03:24 PM | #20 | |
Rep 201
