05-25-2020, 06:20 PM | #1 |
Rep 11
F10 reliability
Hi all,
I currently own an E60 M5 (9k miles on rebuilt engine), but I am looking to make the move into an F10. I am a bit concerned about the reliability, some posts say that a tune could likely result in a bent rod, or other such failure. It seems a bit odd to me as there are a few M5's on stock internals running 800 plus bhp in the UK, with one of them running 1000bhp. I know the E60 raised the bar with reliability issues, but am I in for a world of pain with an F10 M5? I'd be looking at pre lci cars mainly, as low miles as possible, dct (we didn't get the manual) and no warranty as I'd not be buying from BMW. I was planning on changing the injectors and rod bearings as a precaution anyway, but is there anything else I should be concerned about? |
05-25-2020, 07:56 PM | #2 | |
Rep 486
I was looking into an f10 as well. Coming from an e90 m3. If you cannot afford a rebuild, or spare engine. I probably wouldn’t do it. The miles on the car don’t matter. As a matter of fact. Your probably better off with high miles, because if it lasted it probably has a good rotating assembly. And most likely has all maintenance (including injectors already replaced) Just do the rod bearings and you should be okay. |
05-25-2020, 08:29 PM | #3 |
Rep 626
The post 2013 engines are reliable. Most of the major problems are with (poorly) tuned engines. They are not cheap when maintenance is required beyond the routine stuff, but if you can afford the car you should be able to afford the routine maintenance and wear item costs. The S63T does not have a rod bearing problem (with above listed caveat)
F06 M6 Grand Coupe CP
05-25-2020, 08:38 PM | #4 | |
Rep 486
How hard is it to find one of these in a 6 speed manual? That’s is my only preference I just tried a couple m5s that I’m interested in realoem they are post 2014 and all day s63N. Maybe I can try ista to check the engine ? Last edited by bmwpower603; 05-25-2020 at 08:44 PM.. |
05-25-2020, 09:25 PM | #5 |
Rep 4,209
Overall you'll want to find a car that has a good service history and has been well taken care of. The most common issue that I've seen is turbo coolant lines failing but can be replaced easily. As for the tunes, you will want to make sure its been tuned by a proper tuning shop (there is a whole threads about this already). I'd highly recommend getting the car you want to buy inspected at a BMW dealer for a PPI (Private Purchase Inspection, it costs about $200 here in the states). From what I've seen, its very hard to find a 6 speed manual for these cars. But you could wait for one to pop up. I personally love the 7 speed DCT for how easy it is to use and how quick it shifts.
05-26-2020, 08:27 AM | #6 |
Rep 538
05-26-2020, 08:28 AM | #7 | |||
Rep 11
I managed to afford a rebuild on my E60 (there's the thick end of £15k I will never see again), whether or not I have the stomach to do it on an F10, not sure. My E60 has less than 90k on it, given the finite life of turbo's etc, a lower miles one is more appealing. Quote:
I am hoping that my budget will stretch to a later car, but what is the issue with the pre 2013 cars? I've read posts about the bearings as well, and for the small cost of having them and the injectors changed, it's worth it given the price of new cranks / engines etc. Quote:
Thanks everyone for your replies. |
05-26-2020, 09:03 AM | #8 | |
Rep 538
Personally, I'm not sure I'd buy any year w/o a warranty, but I'm not big on risk. *on a stock or properly/safely stage 1 tuned car that isn't being ragged on at low RPMs |
05-26-2020, 11:21 AM | #9 | |
Rep 73
05-26-2020, 01:10 PM | #10 | ||
Lover of the 3rd pedal
70
Rep 103
Drives: '16 M5 6spd; '13 Audi S4 6 spd
05-26-2020, 03:42 PM | #11 | ||
Rep 11
05-27-2020, 09:26 AM | #12 |
Rep 538
I don't think we know for sure. From what I've read, the theory is those with bad consumption didn't have a "proper" break-in, but that doesn't explain why the following years seem to have it much less. Perhaps some stealth revision to the oil separator or other part of the PCV system? It's annoying that there isn't a good oil catch can setup for cars with stock intakes.
And when I said "haven't been ragged on", I wasn't talking about driving it hard like it's meant to be, I was referring to stuff like going hard before warmup or a penchant for going WOT from ~2K RPM or something. |
05-28-2020, 06:31 AM | #14 |
Rep 11
