      01-20-2015, 12:59 PM   #1
anthonyadf
anthonyadf's Avatar
Drives: BMW F10 520d SE
Vanity Light Fuse Passanger Restraint System Issue
Hello, I am having the exact same issue as 'Eliottdds' posted a few years ago and hoping that someone can help!
This was the post:
Hey guys -
I realize this is probably in the wrong forum - so mods please move if needed.
I finally got around to installing the LED interior light kit from ECS tuning - looks great. The trim removal kit, for me, was a god send, & something I can always use in the future.
The install all went without incident, until the end. I was installing the LAST LED bulb in the passenger vanity mirror, when my small metal screwdriver clipped a contact. A small spark was seen, and no more vanity lights. Yes, I realize I should have taken out the entire assembly to place the bulb - I did do with all the others......but what's done is done.
Everything is working great, all the interior lights, maps, puddle, footwell, glovebox, works fine. I am assuming I just knocked out a fuse.
Reading the manual, I know there are 2 fuse boxes.
I am hoping someone knows the exact location for this fuse. There is a piece of paper located in the trunk box, but it really doesn't give me an exact location, or what fuse it could possibly be.
Any help or insights would be greatly appreciated!
Correction - after starting the car, I now see a warning light - Passenger restraint system malfunction - ?????
all from a stupid vanity light bulb - it is heading in Tuesday for it's 1200 mile service
anthonyadf
      01-20-2015, 01:15 PM   #2
darkz
darkz's Avatar
2016 BMW X5M  [0.00]
2013 BMW M5  [4.50]
2012 BMW X3  [4.50]
2013 Ford F150 FX4  [5.00]
might be easier to just ask the dealer since you are in anyways?
      01-20-2015, 01:34 PM   #3
nynd
Drives: X7
I'd say check fuses 5, 13, 16, 48 and 66. Looks like these are coded for lights.
      01-20-2015, 02:18 PM   #4
anthonyadf
anthonyadf's Avatar
That comment was from the previous post as I mentioned at the top.
I am not in the dealer anytime soon...
anthonyadf
      01-20-2015, 02:19 PM   #5
anthonyadf
anthonyadf's Avatar
I have tried those and no luck!
anthonyadf
      02-04-2015, 02:38 PM   #6
Jaragator
Jaragator's Avatar
Drives: 2013 Sapphire Black F10 M5
Did you figure it out? I am having the same issue
      02-05-2015, 12:07 AM   #7
Tisaksen
Tisaksen's Avatar
Drives: M3cs
Same thing happened to me. It was my fault though. I brought it in and they replaced the motherboard that controls all the sunroof and upper lights no questions asked
      02-06-2015, 12:28 PM   #8
Bottch77
Drives: F90 Competition, McLaren 12C
I am looking to do this mod. Any advice to avoid these types of problems?
I was thinking of simply disconnecting the battery before starting and then realized the bulbs are polarity sensitive and could be 180 degrees off...
      02-06-2015, 01:15 PM   #9
Tisaksen
Tisaksen's Avatar
Drives: M3cs
I tried to pry out the vanity light bulb with a screw driver. Dont do that lol
      02-06-2015, 01:34 PM   #10
Jaragator
Jaragator's Avatar
Just make sure you disconnect the light completely when installing the bulbs, removing and reinstalling the heat shields. Any metal contact will blow the fuses. And good luck finding a good fuse diagram. The one in the car is useless and I couldn't find a good one online.
      02-06-2018, 11:16 PM   #11
Archiebabes
Drives: 13 F10 M5 15 M4 15 RCF R35 GTR
Had the same problem on the first post.
Had to replace the number 8 fuse which is 7.5 Amps located on the glove box.
Used ISTA+ to clear the errors.
It's all good now.
      06-03-2018, 06:36 AM   #12
Birty
Drives: 5 Series F11
I had same issue on my 5 Series estate (F11) the fuse number was number 32 which is a 7.5 Amp located in the glove box.
      03-18-2020, 01:39 AM   #13
Sancheez
Most likely your slip-ring (item that provides connectivity between Air Bag and the rest of the harness while steering wheel can still turn) either got disconnected or wires broke off. You do need to take it to a dealer to have it checked and replaced defective parts myprepaidcenter
      05-29-2020, 02:51 PM   #14
Coolcat12
Drives: Bmw 550i 2013
It's all good now.
Hey archiebabes i had the same problem and fixed it by replacing the fuze if i were to use a program to get rid of the error i still have will the passenger airbag still work because it still shows the error.
