      03-24-2015, 07:18 PM   #1
e92MMM
e92MMM's Avatar
36
Drives: e92 m3 frozen
drive train noise in sport+
Is anyone else getting a clunking sound when throttle is applied in sport plus setting, all gears in manual only. it is very bad cruising on the highway in 4th 5th just tapping on and off the throttle. It is only the very initial throttle application and it only has to be a light tap. Just enough to jerk the car back and it is most apparent in sport+ with the aggressive throttle response. I then experience some forward clunk when i come off the throttle as well. It does not happen in other throttle setting as throttle is applied smoothly ant therefor not producing the clunking sound and feel.
I have had the car completely gone through by BMW and they found nothing with the differential or anything else. I feel it comes more from the front of the car and is not the differential. i have sheered a diff bolt on an e92 m3 so i know what a diff moving feels like. this is a similar jolt forward and back when on and off the gas though.
Bmw tech reset my dct apparently and said it could have been the transmission but the problem is still there.
Anyone experience this or heard any similar issues? any help would be much appreciated !
Carrera white 991 GT3
Brilliant white M5
69 Plymouth RoadRunner 472 HEMI
68 528 hemi dodge dart
69 598 jon kaase boss mustang
      05-21-2015, 07:26 AM   #2
Thunder43
Thunder43's Avatar
10
Drives: 2013 F10 M5
I've noticed this as well on my 13. Chalked it up to the more aggressive shift mapping as it is much less pronounced on D1 and D2.
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
      05-27-2015, 04:22 PM   #3
Thunder43
Thunder43's Avatar
10
Drives: 2013 F10 M5
After further review of your post and more mileage in my car, I have the same exact thing. It is not shift mapping. Happens on and off gas.
      06-19-2015, 03:59 PM   #4
celicatoe46m3
Drives: E60 M5 & E46 M3
Me too.
      08-27-2015, 01:45 PM   #5
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
me too - Most noticeable for me when I go over speed bumps and engage the throttle. Feels like a manual to be honest as it is a DCT. Only happens in S+
      08-31-2015, 12:38 PM   #6
Bigmuz7
Bigmuz7's Avatar
Drives: G16
I have also noticed this , but have just ignored it as it only happens in sport plus my car is september 13 also
      10-11-2018, 12:38 PM   #7
M5f10_87
M5f10_87's Avatar
Drives: M5 F10
hi guys! I have seen some M5 f10 (m6 also) that when your in full sport mode, MDM and all that. The Revs can Bounce, for exampel, if you have your revs at 3k, and you push the gas and let of the gas at the same second it sometimes Bounce a Little bit.
have you Heard or seen this fenomen? I have not seen this on my car yet, but my car is now sleeping for the Winter. I noticed some on the Youtube.
i hope you can understand this strange fenomen, if you don't I will try to explain better.
