12-23-2016, 01:51 PM | #1 |
4085
Rep 1,767
Drives: powered by bootmod3
Thought we'd share a dyno from a recent tune on a customer car in Florida done through our dealer Miami Performance Inc.
Car: M6 Mods: Downpipes, bootmod3 OTS Stage 2 93 octane map Octane: pump 93 octane (98RON) Boost on this run hit 24psi down low in one spot but levelled off to 23psi by ~5800rpm, 21psi at 6600rpm and 19.5psi at redline. One item to point out, at this power level blending in ethanol is not a good idea as you can see in the bm3 log posted below that the HPFP (high pressure fuel pump) is falling under target to 1600psi from the targeted 2900psi. If you've ever dealt with misfires on your S63tu when pushing power, and not using meth or secondary PI injection to supplement and help the fuel system, then we suggest dataloging and paying attention to your HPFP pressure. Midrange power/torque we feel is already maxed out due to where the HPFP is sitting unless we lean it out a bit to 5500rpm and to go higher in that area you'll need meth which is easiest to install or a PI kit that we don't think exists for the S63tu today yet. This is the current state of our OTS Stage 2 93 octane map. We're looking to get a bit more dyno runs in as its very likely there's a few more reliable ponies in there at 6k rpm. Let us know if any questions at all. ![]() ![]() ![]() Last edited by proTUNING Freaks; 12-23-2016 at 02:24 PM.. |
12-24-2016, 08:25 AM | #4 | |
4085
Rep 1,767
No, Enzo is a shop in NY. We're located in Toronto, Canada.
![]() Just shedding some light on numbers we got and sharing data with datalogs of the runs (you can click on the images and take a look at the run btw). The fuel system limitation in midrange (3-5k rpm range) in terms of the fuel system and the high pressure fuel pump is what it is. Most if not all going past these power levels seem to be doing it with meth, either JB4 controlled or Aquamist or similar, which makes sense as it helps the HPFP from dropping out and you get the octane to push harder. This is on stock turbos also, not upgraded Stage 2 turbos. |
FSociety3648.00 |
12-24-2016, 11:36 AM | #5 |
![]() ![]() ![]() ![]() ![]() 239
Rep 880
Thanks for sharing your data with us.
So what is the minimum safe fuel pressure at redline? I assume you're saying 1600psi is too low for your current power levels? And when do we need to look at replacing stock injectors; not sure what the stock flow rates are. I know you guys are still in beta testing and appreciate the info. |
12-24-2016, 12:34 PM | #6 | |
4085
Rep 1,767
No, didn't say 1600 specifically was too low ![]() With meth there's quite a bit more on the table as its used as a bandaid for this fueling limitation. You could also run a bit leaner AFR in that area which will help. With direct injection injectors on this motor there aren't any injector upgrades available ![]() ![]() Just sharing some in-depth data on the fuel system on the S63tu seeing it struggle to keep up at this power level in midrange even on pump gas. If you threw in ethanol on top you'd max the fueling out even sooner. |
FSociety3648.00 GreenRacingM30.00 |
12-24-2016, 12:43 PM | #7 |
![]() 1088
Rep 2,235
If you limit mid-range torque then you help preserve your clutches as well as not having this fuel pressure problem - seems like a good idea to me
12-24-2016, 01:08 PM | #8 | |
4085
Rep 1,767
12-24-2016, 11:18 PM | #9 |
![]() 1088
Rep 2,235
What is the reason behind it dropping down in the midrange then picking back up to the target again? Is there still plenty of room up at the high end of the range, i.e. With stage 2 Pure turbos
12-25-2016, 11:26 PM | #12 |
IG @BmwF9x_G80
![]() 3648
Rep 7,475
Drives: F98 X4MC, F90 M5, F80 M3 ZCP
Garage List 2020 BMW X4MC [0.00]
2018 BMW F90 M5 [0.00] 2017 BMW M3 ZCP [0.00] 16' BMW X4 M40i [10.00] 14' X3 M-Sport 28ix [10.00] 06 Cadillac STS [0.00] |
This is Pure turbos doesn't count lol
Team & Friends @BM3Tuning @OrlandoAutowerks @protuningfreaks
IG: @bmwF9X_G80 ![]() |
12-25-2016, 11:28 PM | #13 | |
![]() 438
Rep 1,519
Then here it is |
12-26-2016, 12:47 AM | #15 | |
Hide! My wife's coming!
![]() 790
Rep 2,816
I also know a few others on the same tune and mods pushing the same numbers. EDIT*** ignore this post*** you said power band and not power. Misunderstood. Lol
12-26-2016, 09:02 AM | #16 | |||
4085
Rep 1,767
![]() Quote:
If you look closer at the log 24psi is not sustained boost, holds it 4850-5160rpm ![]() ![]() Thanks for sharing. Did you get a chance to get some logs of your runs and look at how your HPFP pressure is doing? Glad you logged AFR on that dyno. I see your car is running 1-1.5 points leaner AFR through midrange than our runs in this thread. That's what we were hinting at earlier. Running 13-13.5:1 through midrange instead of 12.1-12.2:1 will most likely lift the HPFP higher and help on the torque. Then again as some mentioned, maybe clutches would start slipping as this is a DCT ![]() On the Pure Stage 2 run I see your boost is tapered lower to higher as RPM goes up. No AFR trace unfortunately but that's another way to keep that HPFP from dropping out and take advantage of getting more power in the top end. If you guys have any other runs with datalogs to share that are on pump gas specifically and stock turbos/downpipes that'd be great. Without datalogs its just another dyno pull and it won't bring much value to the discussion. |
12-26-2016, 09:08 AM | #17 | ||||
![]() 438
Rep 1,519
I have manual The pic above is not my car but my buddies car on stock turbo n clutch. Yes idk if they have done logs (owners of cars) But only data we do is race cars on event if that helps. Lol. |
12-26-2016, 09:13 AM | #18 | |
4085
Rep 1,767
GreenRacingM30.00 |
12-26-2016, 09:15 AM | #19 | ||
![]() 438
Rep 1,519
Follow the instructions of your tooner and it wont blow up. Logs n dynos are good table to see improvement and changes. But numbers dnt mean anything if it cnt perform on the street |
12-26-2016, 09:17 AM | #20 |
4085
Rep 1,767
12-26-2016, 11:39 AM | #21 |
![]() 438
Rep 1,519
I have over 400 pulls on my car 30-200 various speeds and kept religious gas consistency. 100oct and e85 FTW
12-26-2016, 02:51 PM | #22 | |
Rep 880
Stock turbos, stock downpipes, 3 gallons E85 + 91.
2014 "AW/SO"me M5
ARC550423.50 |
