      05-06-2019, 08:12 PM   #1
induc916
Drives: 2014 M6
Smoke when coming to a stop
So has anyone had issues with either PCV system or Turbos causing couple puffs of smoke when coming to a stop after a couple pulls?
See signature for mods. I don't want to jump to conclusions on if its turbo or not. I'm not burning any oil, had a black stone analysis done and no issues shown.
      05-07-2019, 04:19 AM   #2
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
same here, before few days i was driving the car hard with sport+ mode then after few pulls i changed mode to efficient same time my friend was behind me and he saw white smoke coming from the right muffler only, few seconds and gone....
so the time from sport+ to efficient mode the white smoke came out
      05-07-2019, 09:30 AM   #3
induc916
Drives: 2014 M6
I wonder if oil weight has anything to do with it, yes I know i'm catless but this didn't start happening till i upgraded turbo, tune and ran meth.
      05-07-2019, 11:37 AM   #4
Jasoneo5
Drives: 997 TTs, GS-F, RS6, M6 GC-sold
Same here - have been having the same occurrence for a while - but only happens periodically and not necessarily after a pull, but always been decelerating to a stop. Hoping its just unburnt fuel? Will be doing a oil analysis next month
BM3 Stage 2 + DP's
      05-07-2019, 11:58 AM   #5
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
I used to get this all the time when I 1st got the car
It seemed to have stopped for a long time now though
      05-09-2019, 12:51 PM   #6
jairomvp182
jairomvp182's Avatar
510
Drives: 22 X3MC
thats how two m5 i know started, after pulls and sometimes just driving around oil smell coming from the exhaust, after a while then smoke, end result cylinder 8 on both cars passing oil, remember that the exhaust manifold runs on both banks so it will smoke on both sides even if its just one cylinder.
22 X3m
10 e90 335i 610whp
13 M5, 11.0@131 Fabworx DP,Precision Tune 650whp+
11 E92 335xi 12.5@113MPH,362whp/438wtq GONE http://www.youtube.com/c/jairomvp
Instagram:Jairomvp
      05-17-2019, 06:36 AM   #7
OneExtra
OneExtra's Avatar
Drives: None
Looking at how you drive you have probably cleaned any old crud well and truly out!
      05-18-2019, 01:55 PM   #8
schnell1982
Drives: FAST
I have had some friends with the same experience as you.
It would mainly be on cold start and after some hard pulls
The issue was bad turbo seals
If you had contentious oil smoke; then I would be looking at the PCV system.
      05-18-2019, 04:38 PM   #9
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
Coolant leak in to cylinders.
      05-18-2019, 07:41 PM   #10
Jasoneo5
Is this a critical problem that needs to be fixed ASAP, or is it ok to wait until it gets worse/more constant?
Thx
      05-19-2019, 03:14 PM   #11
Dng93
Drives: F13 m6
Same thing happened to me also at a red light , big white cloud of smoke when I was switching from sport + to efficient mode. Hasn't happened since been pushing the car really hard after with no problems
      05-20-2019, 05:28 PM   #12
schnell1982
Drives: FAST
Thx
Any potential issue I would advise to get diagnosed before your issue gets worse. At this point, all we have is speculation
      06-01-2019, 05:02 AM   #13
theinfamousdrew
I'm The Captain Now
theinfamousdrew's Avatar
501
Drives: X5M/X7
Subscribed.
This happened for the first time yesterday. The car is catless and tuned.
Driving normally light traffic, came to a red light and a big cloud of whitish smoke followed me.
I pulled over and the smoke had started to subside and after a couple mins was gone. Continued to my destination and when I restarted the car it was fine.
Nothing on the drive home.
Scared the crap out of me since I just bought this thing. lol
It is still under CPO warranty but I dont have stock cats to throw on to bring it in.
Current mods:
Tune
RK intakes
Catless downpipes
Axle back exhaust
Turn on. Tune in. Drop out.
IG: @InfamousCarGuy
      06-04-2019, 07:19 PM   #14
jairomvp182
510
Drives: 22 X3MC
update, both cars i know having the same issue end up having oil on top of the piston.
22 X3m
10 e90 335i 610whp
Instagram:Jairomvp
      06-04-2019, 09:18 PM   #15
Jasoneo5
Nice to know. Is this serious & what would cause it?
      06-04-2019, 09:36 PM   #16
jairomvp182
510
Drives: 22 X3MC
Well it looks like heat could be a big issue, 2 out of 4 cars were cylinder 8, one cylinder 6 and one on 5 if I'm not mistaken, ether piston cracked or ringland gave up and this case, they are all close friends of mine, I heard it's about 40 hours to change a piston on this cars.
22 X3m
10 e90 335i 610whp
Instagram:Jairomvp
      06-04-2019, 10:22 PM   #17
boots
Curve Thrasher
boots's Avatar
623
put 10 onces of sea fog into your oil and put some miles on it. it will go away. mine did as well as one of my friends.
Country run
      06-05-2019, 04:26 AM   #18
theinfamousdrew
I'm The Captain Now
501
Drives: X5M/X7
Seriously?
This happened again to me yesterday and its starting to worry me.
Yesterday it was a smaller instance than the other day.
I may reinstall stock intakes, downpipes, and flash it back to stock and take it to the dealer. I still have a warranty through Sept.
IG: @InfamousCarGuy
      06-05-2019, 07:59 AM   #19
boots
Curve Thrasher
boots's Avatar
623
yes. pick up a bottle from o'Reilly's. My bud and I here have no more smoke.
dont worry about the smoke. this will clean out your motor. no need to remove your items
Country run
      06-05-2019, 12:47 PM   #20
Jasoneo5
Thank you
      06-05-2019, 07:17 PM   #21
boots
Curve Thrasher
boots's Avatar
623
your welcome.
I added mine then drove couple hundred miles. changed oil and no more smoke. it will work for you
Country run
      06-06-2019, 07:23 AM   #22
theinfamousdrew
I'm The Captain Now
501
Drives: X5M/X7
Yesterday I did some investigating and pulled my intakes off.
There was a substantial pool of oil in the plastics piece just before the turbo.
It seems that under hard cornering this would easily spill over into the turbo causing smoke.
I cleared it out and will monitor it some more.
IG: @InfamousCarGuy
