Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Regional Forums > USA - Southwest
      01-22-2020, 03:37 AM   #1
bmwm51980
Drives: bmw m3,m4,m5
Ram air filters good or bad
Hi thinking of fitting after seeing diy post
Told can cover maf sensor in oil is this true or
Fit ? Have some on order
      01-22-2020, 05:04 AM   #2
M5theonlyone
Drives: BMW M5 V8 Gunmetal
2013 BMW M5  [5.00]
Don't use oil based filters and better still stick to stock, don't make a lot of difference just more noise.
      01-22-2020, 05:06 AM   #3
bmwm51980
There. Not oil based as there made of sponge
      01-22-2020, 05:25 AM   #4
M5theonlyone
2013 BMW M5  [5.00]
Should be ok then if sponge,'ram air' with tubes coming to grille? then will it be ok in a downpour.
      01-22-2020, 05:37 AM   #5
bmwm51980
Yea haven't run any tubes to the grill as it sits in the Oem air filter boxes but I may fit an air duct from the grill that replaces Oem
Air duct to feed the foam cone
      01-22-2020, 05:45 AM   #6
M5theonlyone
2013 BMW M5  [5.00]
Sounds good,will you be cutting the boxes open or just directing it to the openings at the bottom of boxes.
      01-22-2020, 05:49 AM   #7
F10CPROG
Drives: BMW F10 M5 Competition
i have read that these aren't great for filtration. Alot of dust and grit gets into inlet tract. Not sure how true this is...
Hyundai i30N
Porsche 986 Boxster S
      01-22-2020, 05:50 AM   #8
bmwm51980
What would u recommend guess lot people use them
      01-22-2020, 05:51 AM   #9
bmwm51980
Just directing the air to the bottoms of the Oem
Boxes really from
Air coming in from
Grills really
