      02-19-2020, 02:45 PM   #1
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
MirrorTap and V1
Hardwired my V1 with the mirrortap wire harness....isnt the V1 supposed to turn off after x amount of time? Maybe I tapped into different power than whats needed to turn off...?
      02-19-2020, 07:22 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
V1 turns off as soon as power is cut. Does it turn off after the car goes to sleep? My camera is tapped in to a "wake state" supply so it comes on as soon as I touch the door handle as does the V1.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      02-20-2020, 07:21 AM   #3
Fast.F10
Extruding Elements
Fast.F10's Avatar
Stays on until I turn the V1 off manually. Need to open it back up and see where I tapped into...as apparently it was the wrong power source. Does the attached look proper? Not mine, an image I just found online.
      02-20-2020, 12:27 PM   #4
arucano
arucano's Avatar
The color coding you are using is correct. The 12V supply (Green /Brown) is switched on and off by the car access system. As soon as you unlock the door it switches on and it stays active for a while after you lock it. Have a look at this: https://www.newtis.info/tisv2/a/en/f06-650i-cou/s4MNsTV
Connector A60*1B pin 3 for 12V and pin 10 for ground.
Fast.F10516.50
      02-27-2020, 06:33 PM   #5
cudakid03
Drives: 2013 M5
They should both go in the black connector from what I can tell.
This works for me:
Fast.F10516.50
      02-29-2020, 08:35 AM   #6
Fast.F10
Extruding Elements
Fast.F10's Avatar
So getting tired of turning on/off so back at this. The above images do not looks as mine is on my 2016 CP F10 M5. Here is this link that I should be referencing...but cant seem to locate a similar diagram: https://www.newtis.info/tisv2/a/en/f10-m5-lim/
Here is what I am looking at:
      02-29-2020, 08:59 AM   #7
Fast.F10
Extruding Elements
Fast.F10's Avatar
I think I have figured it out...https://www.newtis.info/tisv2/a/en/f...f22/1VnXvXgTJk
Now to figure out to pull that front trim off.
      02-29-2020, 09:24 AM   #8
Fast.F10
Extruding Elements
Fast.F10's Avatar
BINGO! You do not tap into the connectors on the top trim panel...rather the connector on the "arm" for the mirror.
/closed
      02-29-2020, 09:45 AM   #9
arucano
arucano's Avatar
I have the same hookup as detector cudakid30. With Pins 3(+)and 6(-) the detector works with the ignition status. With the pin 3 and pin 10 connection, the detector will have to be switched on and off manually. (my pictures do not match the clarity of the others above)
      02-29-2020, 11:06 AM   #10
Fast.F10
Extruding Elements
Fast.F10's Avatar
Yeah, I was unaware of the 2 connector behind the trim near the windshield and thought you were to tap into the connector(s) from the top roof panel.
      02-29-2020, 04:03 PM   #11
Fast.F10
Extruding Elements
Fast.F10's Avatar
...and now Passenger Restraint System Malfunction LOL.
      02-29-2020, 04:24 PM   #12
Fast.F10
Extruding Elements
Fast.F10's Avatar
...seems to be a common occurrence due to the roof panel: disconnecting and then powering on the car with leaving those noted above 5 plugs disconnected...to test rear view mirror tap test. Will stop off at dealership on Monday to have them clear unless there is a DIY.
      05-03-2020, 10:19 AM   #13
94jedi
Drives: 2009 e92 M3
Thanks for blazing the trail on this @Fast.F10. I just bought a uniden R7 and Blendmount w/ the mirror tap setup. going to be installing it today/tomorrow I think.
      05-25-2020, 03:19 PM   #14
94jedi
Drives: 2009 e92 M3
Following up on this post - I installed my Uniden R7 and blend mount today using the mirror top. Although I couldn't get that darn plug out and had to just wing it by pressing the wire taps by hand, it was a pretty easy job thanks to this thread and everyone's input. Thanks guys!
