PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
non run flats
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
04-11-2011, 11:57 AM | #1 |
Rep 739
non run flats
I have an 07 335i coupe sport package and the Sa told me that I have to get run flats because the car will not drive properly with out them is this true?
04-11-2011, 12:01 PM | #2 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
SA is a moron. Don't ever listen to a word they say again!
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
04-11-2011, 02:18 PM | #5 |
Rep 1,754
That's the official company line, and they have to tell you that. But it's BS. Ditch 'em and you will never look back! Your dental work will last longer, as well...
04-11-2011, 03:20 PM | #6 |
Moderator
369
Rep 4,745
Just to confirm, non runflats work quite well on the 335i.
It is very common to use them instead of run flat tires. Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
04-11-2011, 11:29 PM | #8 |
COBB'ed
65
Rep 2,228
I'm not sure about your service advisor, but ditching the RFTs was one of the best mods I've done to the car, and it still drives "properly"...
13 Mini Cooper S 08 E92 335i (SOLD) |
04-12-2011, 02:30 PM | #9 | |
878
Rep 3,699
I have non-runflats on both my car and my wife's. MUCH better in noise and harshness vs. runflats. Runflats were horrible.
04-12-2011, 07:11 PM | #10 | |
Rep 3,175
Re-read my response and think "sarcasm." SA told the guy his car would not drive "properly" without RFT's... hence the sarcastic response. Sheesh, it isn't as funny now that I had to explain it. For the record I switched from rft to non-rft's. |
04-13-2011, 03:38 AM | #11 |
No 55mph
1622
Rep 8,476
After hearing what comes outta the mouths of some of these SA's I begin to wonder if the BMW job application states 'looking for morons with no prior automotive knowledge'
Of course you can run non-RFT's - prolly 85-90% of the members on this forum switch to non RFT's. I quit using mine after about 7000 miles. I use 17" Blizzak non-RTF's on my winter setup & 18" Conti DW non-RFT's on my summer setup. Ride is much better (not as harsh) with the non-RFT's even though I went to a lower profile tire. Handling is every bit as good with the way I drive. The non-RFT's do have more flex in the sidewall because they aren't as stiff as the RFT's - but you can remedy that by adding about 3-4psi more to the tires. Just remember that you will need either a Mobility Kit or a Jacking Kit/Compact Spare in case you get a flat (or a really good service that will come out and take care of a flat in a short time).
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
