      11-27-2013, 01:15 AM   #1
v3n0m
Drives: 2013 MCB M5
DIY: Removing airbag warning sticker
I'm trying the method where you use acetone to remove the sticker. There's a post describing the process for the previous M5, but I'm going to give it a shot with the F10 M5.
Here's the original post:
http://www.m5board.com/vbulletin/e60...-stickers.html
I'll post back with results and before, during, after pix once I get it done.
      11-27-2013, 05:28 AM   #2
Spinny02
Spinny02's Avatar
      11-27-2013, 07:58 AM   #3
B-1Pilot
Yankee Air Pirate
B-1Pilot's Avatar
151
Drives: '14 M5 w/CP
Probably not going to work on alcantara... They can be replaced with euros spec ones, but they are like 200 a piece
2020 ///M5 || 2019 540XI || 2014 ///M5 w/CP || My Epic ED trip report|| || 2009 BMW R1200RT
      11-27-2013, 10:06 AM   #4
v3n0m
Drives: 2013 MCB M5
So here are pix of the process.
1st is when I started.
2nd is during.
3rd is final.
So the sticker comes completely off, however there is a slight imprint left. Since it's lighter, I don't think it's due to exposure to sun discoloring the surrounding areas. It's most likely residual adhesive.
Even with the imprint, to me it looks a lot better than with the sticker. Besides, this cost me $2.50 for the acetone from Walmart (nail polish remover) and a bit of time while I was watching TV.
I'm probably going to try some alcantara reconditioning at some point to remove the imprint, but I'm satisfied at the moment.
      11-27-2013, 11:50 AM   #5
v3n0m
Drives: 2013 MCB M5
Cleaning it up with a bit of woolite right now. Seems to be helping. Will post final results after it dries.
      11-27-2013, 12:18 PM   #6
v3n0m
Drives: 2013 MCB M5
So after the first woolite cleaning, you can barely make out the residual imprint.
Just saved myself $200 bucks per side!
      11-27-2013, 04:37 PM   #7
Spinny02
Spinny02's Avatar
Awesome! Thanks
      11-27-2013, 04:39 PM   #8
B-1Pilot
Yankee Air Pirate
B-1Pilot's Avatar
151
Drives: '14 M5 w/CP
wow, Im impressed... wonder if they will charge you for new ones one a lease...
      11-27-2013, 08:44 PM   #9
Spinny02
Spinny02's Avatar
Doubt they would notice
      11-27-2013, 08:45 PM   #10
Spinny02
Spinny02's Avatar
How is the smell after ?
      11-27-2013, 08:45 PM   #11
v3n0m
Drives: 2013 MCB M5
Just did the passenger and it turned out even better. Can't even tell there was a sticker originally.
      11-27-2013, 08:47 PM   #12
v3n0m
Drives: 2013 MCB M5
There is absolutely no smell after it dries.
Also, the second one tool 10 minutes.
Dabbed one end, used a tweezer to lift. Then put a little bit of pressure peeling back flat while using a toothbrush to apply acetone to the edge that I was lifting. Came off in one piece and much quicker than the first time.
      11-27-2013, 11:48 PM   #13
v3n0m
Drives: 2013 MCB M5
Just say they fell off.
      11-28-2013, 10:00 AM   #14
Spinny02
Spinny02's Avatar
V3n thanks for starting this off and for being the first! I still have a long way to go before it will come of in one go.
So I am finished my pax side. It took about an hour. Lot of lessons learned. At the end I still had a bunch of glue left. I am a big RC Heli guys and happened to have some CA ( superglue) remover so I tried it and it worked great!
I may try to use it instead of the nail polish remover on the driver side.
      11-28-2013, 10:20 AM   #15
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
My thanks as well. I wouldn't have thought you'd be able to do that with the alcantara material either. I put black vehicle wrap material over mine quite some time ago and it was ok but not as good as your process. I wonder if having that wrap material over the warning will help it come off in one piece if I try this method? Probably won't hurt at least.
      11-28-2013, 10:45 AM   #16
Spinny02
Spinny02's Avatar
Driver side done 15 min!
The super solvent was the key. I put it on one edge then let it sit to lift. About 15 min later I started to peel the edge with one hand and kept apply the solvent under the peel as so worked the sticker off.
Then cleaned it up with a bit of solvent and nail polish remover then A light sponge with tide and some water to make it look stock.
      11-29-2013, 04:30 AM   #17
boots
Curve Thrasher
boots's Avatar
623
Kwell. I'm next on the list for this procedure. Hey John I have 1/8 rc buggies
