      03-30-2014, 05:37 PM   #1
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
CYBA Exhaust Tip DIY install
Tools - Allen Wrench (provided) and 13mm Combination Wrench
I got the Stainless Steel tips, should be the same for Dry CF and Gloss Black
Removing the stock tips, start with the inner tips, that way you can get a better grasp of the outer tips since they sit in more. Depending on how long they've been on, it will take more effort. I simply twisted to the left slowly, turn by turn as mine have been on for a year and they had some grime built up. I did not need anything like WD40, just a lot of effort. I was a little discouraged at first, but they will come off. After a few turns to the left, I gradually pulled out as I turned.
Installing the tips - at first glance you'll notice there is one welded line on the inner pipe with one allen screw and nut directly above it, this should be the top of the exhaust tip, that way you will not see the remaining two welds as they will sit on top.
Loosen the three nuts, then loosen the three allen screws so that it sits flush with the inner pipe - that pipe fits perfectly over the exhaust tube with little room, so if you dont loosen the allen screw it wont fit over properly.
Fit the exhaust tip over the exhaust pipe, at this point you will notice that w/o removing the diffuser, the top nut/screw with the weld will be hard to fasten when its sitting in its top position. What I did was tighten the top allen screw and then its corresponding nut as it sat facing the ground from the bottom to the point that I got resistance. (Its important to tighten the nut prior to rotating it to the final position, you will see why after you rotate it) I would then rotate the exhaust tip so that it sat facing up in its final position. Then continue to tighten each of the other allen screws to the point of resistance. Then tighten the nuts - the nut secures the screw, so tightening the nut should be the last step after the screw is where you want it.
Tips - I started with the inner tip first and worked my way out, I felt it was easier to align the outer tip using the inner tip as a reference point since the inner tip sits out more.
Also, from reading others' posts, it sounded like a few people spent most of their time trying to align the second pair of tips to the first pair. I simply measured the distance between the edge of the inner stock exhaust tube to the edge of the installed exhaust tip from the first pair/side and used that on the 2nd pair/side, worked out perfectly.
The outer exhaust tubes are wider in diameter than the inner exhaust tubes, so don't be alarmed when you find yourself not screwing in the allen screw as much.
Just as a reference, Im pretty terrible as a DIY'er, I am maybe a 4 out of 10, and I did this pretty easily. Took me about an hour, with the first tip taking up about half the time. Removal was 5 minutes.
I plan to check on them to make sure my screws/nuts are tight, and as my wife warned, just make sure the tips arent hot.
Good Luck
2016 991.1 911 Carrera GTS
      03-31-2014, 08:47 AM   #2
PatrickC23
PatrickC23's Avatar
      03-31-2014, 09:20 AM   #3
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
Originally Posted by PatrickC23
Please take a pic of the behind the oem tips, thanks
      03-31-2014, 09:56 AM   #4
PatrickC23
PatrickC23's Avatar
Ill take one tonight - you mean from directly behind one side?
      04-11-2014, 03:48 AM   #5
M5essex
M5essex's Avatar
England
635
Drives: RR sport SVR, Vent S, 650s spi
Thanks for your detailed instructions Patrick. Very helpful. Did you do all of this without having to raise the back on a ramp or even a trolley jack? I've bought the carbon tips and a little disappointed with the size. The two rings don't give the perception of increased diameter like the solid ones, like yours, do.
      04-11-2014, 08:19 AM   #6
DrewM5
Drives: SG E60 M5
How did you get yours to fit so far in (i.e., without protruding from the bumper much)? The diameter of the exhaut pipe is larger for the last 4 or so inches. If I mount them at the innermost part of the pipe right before the diameter gets smaller, they still out abouy an inch or more. When I tried to mount where the diameter was smller, the mounting bolts were not long enough to secure the tips. I have the CF tips. Maybe they are different?
      04-11-2014, 03:10 PM   #7
PatrickC23
PatrickC23's Avatar
No lift whatsoever, just laid some cardboard and got on the ground. I thought that about the CF tips as well in regards to the inner silver ring.
      04-11-2014, 03:14 PM   #8
PatrickC23
PatrickC23's Avatar
I thought of you as I installed mine, b/c I distinctly remember you saying that yours sat out farther than you liked. The inner pipe on the tips must be the same size thought I would think, and that what determines depth of the allen screws. I figured you must have tightened them to the wider portion of the exhaust tube. I, however was able to push them in and tighten the allen screws to the thinner portion of the tube. Did you do one particular allen screw first? When I did that, it appeared as if I didnt have enough length in the screw, but if i turned each a little bit at a time, I was able to evenly tighten them.
      04-11-2014, 03:49 PM   #9
M5essex
M5essex's Avatar
England
635
Do you think the cp exhaust tubes are different/thicker than non cp tubes?
      04-11-2014, 03:53 PM   #10
PatrickC23
PatrickC23's Avatar
Actually thats a very good question - I hav no clue. CYBA should check if hes going to sell them to those with CP exhausts.
      04-11-2014, 04:36 PM   #11
M5essex
M5essex's Avatar
England
635
I asked like 20 times if it's the same and I never really got a concrete answer. Just confirmation that they just slip off and on easily and stock tips are 76mm... I pick my car up next week and have the carbon tips ready to do a self install. I'll let you know how I get on...
      04-12-2014, 11:11 PM   #12
PatrickC23
PatrickC23's Avatar
Side view
      04-16-2014, 08:55 PM   #13
Spinny02
Spinny02's Avatar
Looks great!
      05-31-2014, 01:55 PM   #14
NikB316
NikB316's Avatar
52
Drives: 2014 M5 Competition, F83 M4
Can someone confirm these work with the comp package? I can't twist my OEM ones off for the life of me...
2014 M5 Competition Alpine/Sakhir
BMS Tune. Undercover Performance Custom Downpipes & Connector. H&R 10mm Spacers. BMW CF Rear Spoiler. IND Cosmetics. ALP & BEL Radar & Laser.
2011 Space Grey E92 M3 AA Gen 2 Lvl 3 586whp 398wtq SAE (sold)
      05-31-2014, 02:06 PM   #15
///SAL
///SAL's Avatar
Dont break your hand
      05-31-2014, 06:49 PM   #16
DrewM5
Drives: SG E60 M5
They do. Depending on the time/conditions, you may need to work them back and forth a little bit.
      06-01-2014, 09:33 PM   #17
Spinny02
Spinny02's Avatar
Yes they do. Took a few days of trying but they do. They look great. I get lots of on them.
      06-09-2014, 10:33 PM   #18
NikB316
NikB316's Avatar
52
Thanks guys, been busy to give it a second shot but with your guys confirmation I'll give it a try. If not just pay the shop to have them on - these OEM comp ones look like crap. Too weak for how the car sound with the catless DP & connector + Exhaust Meister.
When I first got my Exhaust Meister I was so disappointed as I was only able to listen to it with all the glass closed (due to tint). Didn't use it for a couple weeks then and one day I decided to give it another shot. Damn what a nice difference! Gives the car that low sounding rumble it needed with the DPs.
We all know how crazy the noise insulation is in this car but this really made me say wow. Should have remembered even with my DPs how different the car is inside and outside. My buddy has just DP with straight pipes, nothing interfering at all. The car sounds absolutely insane on the outside and the turbo sound is so sick. From the inside the sound is totally livable with no drone and you still get that sweet turbo sound.
Been debating finishing up my exhaust this way...already halfway there with the custom downpipes & connector from undercover.
Anyway, back on topic I'll post some pics of the black tips once complete. All the OEM chrome is totally gone from the door handles, etc and got a nice CF roof wrap (was a cf wrap hater before). The white and black look is coming along nicely!
      12-10-2014, 01:31 AM   #19
falsalem
falsalem's Avatar
Kuwait
13
Drives: 2013 F10 M5 Alpine White
How are the black tips coming along ? Any pics ? I have a white beast with Gintani Downpipes on the way and am considering the black tips...
      02-10-2015, 09:24 AM   #20
Lerxst M4
Lerxst M4's Avatar
Drives: F82 M4
Has anyone used a strap wrench for OEM removal? Seems you should get a pretty good grip with one without damaging the OEMs...or your wrist/hand.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone)
2013 F10 M5 (gone)
2008 E90 M3 (gone)
      02-10-2015, 02:00 PM   #21
AWE46M3
Taiwan
241
Drives: F82
i used my hands to twist the OEM ones off and no problems/damages here. taking off the diffusor helps a lot when putting tips on since they have three locking bolts on each tip.
20 Telsa M3P
19 BMW M4CS AW
19 BMW i3 BEV Fluid Blk
18 RR Velar R-Dynamic P380 Yulong/Blk
      03-08-2015, 12:48 PM   #22
Lerxst M4
Lerxst M4's Avatar
Drives: F82 M4
Thanks for the DIY PatrickC23. I followed it to the letter and it went great!
Have to add that the strap wrench sure made easy work of removing the stock chrome tips.
2018 F82 M4 ZCP
2013 F10 M5 (gone)
2008 E90 M3 (gone)
