      10-18-2015, 12:49 PM   #1
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
2015 footwell light, led?
is it just me or all the kits out there say that footwell are wedge, t10 bulbs?
i took the cover off the driver footwell and they are OEM two LEDs sitting on pcb board.. just that color is warm white.. anyone know exactly housing replacement with 5000K color?
Thanks all!
      10-18-2015, 01:03 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Thanks all!
This is what I have an it's a 5k white. Cannot recall if it's a wedge or regular bulb but had no issues replacing it and did not require a new housing.
https://www.ecstuning.com/BMW-F10-M5...rior/Footwell/
      10-18-2015, 04:50 PM   #3
hybrid_eg
hybrid_eg's Avatar
i think 2013 is different, on the website it says wedge, those are same type bulbs found in door floor bulbs.. on 2015 footwell is actual led PCB panel.. here are pics of what i'm talking about.. two outer bulbs are on when door is on, and likely others are dim amber at night like on top of dome.. i'll have to wire them to 12v to check..
i didn't see any housings sold with 4 prong only two prong which is plug on door side..
However solution is pretty simple, since i only care about them being on when doors are open, take a wedge LED straighten prongs and plug into factory plug.. i'll give it a shot as that should do the trick..
      10-18-2015, 06:16 PM   #4
hybrid_eg
hybrid_eg's Avatar
as anticipated, the board turns amber at night but the light is dim to a point where it can barely be seen, my main concern is when doors are open that footwells are well lit and that was accomplished by inserting wedge bulbs into the connector..
      10-18-2015, 07:39 PM   #5
hybrid_eg
hybrid_eg's Avatar
Here is what door floods look like as well as trunk, decided to drop in a light bar in trunk since no matter what bulb is put in trunk housing, output is crap.. Not this..
      10-19-2015, 09:36 AM   #6
13M5F10
13M5F10's Avatar
Is it possible your footwell is aftermarket? Ive searched BMWParts and other websites and shows all to be the same. That plug is the same on mine. Wondering if your housing got swapped?
LED strip in trunk looks great.
      12-07-2015, 12:18 PM   #7
hybrid_eg
hybrid_eg's Avatar
on my 2015 model, footwell lights were OEM for sure.. however to match rest of the interior bmw went with LED soft white.. as described above you can simply use a wedge LED bulb of your choice instead of buying complete footwell housings from say bimian which are great for under doors but for footwell in my opinion is an overkill.
Since the pictures above, I also changed the dome lights.. super easy to remove as long as you have the right tools.. (amazon sells a panel removal took kit used to remove clips etc.) works like a charm!
http://www.amazon.com/gp/product/B00...rch_detailpage
      12-19-2015, 01:59 PM   #8
carlos3679
Drives: 2013 M5 & 2011 X5M
The trunk looks awesome, where did you buy that bar?
2013 M5
2011 X5M
      02-17-2016, 06:46 PM   #9
hybrid_eg
hybrid_eg's Avatar
You can buy them anywhere.. i bought this particular one at www.ddmtuning.com
reasonably priced and never had them go bad..
      03-04-2018, 09:51 PM   #10
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Hey man I just wanted to say thank you, this post helped me out when doing the foot wells in my 2014.
      03-08-2018, 02:17 PM   #11
hybrid_eg
hybrid_eg's Avatar
no problem! Its a cheap way to do it and you can put t back to stock with your eyes closed :-)
      11-24-2018, 04:11 AM   #12
doodlebro
Drives: '17 X3 35i
Kind of an old thread, but I found a german company which provides a replacment PCB for cars with this setup. I don't have an M5 but my X3 has the same footwell lighting. When they arrive I will post an update on how well they match with the other custom interior lighting I have installed.
https://www.hypercolor.de/Footwell-L...-Light-Package
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      02-19-2019, 04:09 AM   #13
VESPER_125i
Drives: BMW F20 LCI 125i M-Sport
Thanks for finding this. Been looking for a company that sell these chips for years.
AUSf222689.50
      02-19-2019, 01:32 PM   #14
BeachM5nster
Drives: '14 M5
am i the only one that prefers the dimmer warm yellow light over the cold harsh bright white led stuff for interior lighting? exterior lighting bright and 6000k though
pcohen15379.50
      04-30-2019, 07:08 PM   #15
GermanKiwi
GermanKiwi's Avatar
Drives: BMW 535ix
Hi hybrid_eg,
Sorry for reviving a years-old thread - I stumbled across your post here, which shows your LED strip-light in your car's trunk (photo above), which is exactly the kind of solution I've been searching to use in my F10.
I'd love to know more about where you got it from and how you set it up. I know you wrote elsewhere that you bought it from www.ddmtuning.com, but I can't find it there, mostly because I don't know exactly what to search for, and they seem to sell hundreds of products. Could you help me identify the specific product you bought there?
I'd also love to know how you wired it up. In your photo, I can see that the black cable disappears through a hole in the trunk lid. Did you create that hole (and put the black rubber seal around it) yourself, or is it already there?
More importantly, how did you get it connected to the car's power source? Any details or instructions on that would be much appreciated!
Thanks!
      05-01-2019, 12:20 PM   #16
hybrid_eg
hybrid_eg's Avatar
those were 20CM LED COB panels, you can buy them anywhere.. see ebay link below. I dont remember if rubber grommet was there or not but i simply hid the wires in that area.. you can use any of the existing holes in that metal deck lid to hide the wire. I tapped into power from the original trunk light right next to it.. that's it.
https://www.ebay.com/itm/2-Pcs-20cm-...4AAOSw4CFYyfO9
