11-22-2015, 11:50 AM | #1 |
Hide! My wife's coming!
814
Rep 2,816
Magnaflow Resonated X Pipe
I recently installed Catless Downpipes that was coupled with the Turner Muffler Delete and stock resonators and I found the car had this very high pitched raspiness to it. The cabin drone was too loud and not tolerable for passengers so I went on a mission to find an exhaust system to replace my turner with but before doing that, I had this suspicion that my stock resonators may be the culprit to the high pitched raspiness so I decided to fit on a Magnaflow resonated X pipe and I am amazed. I got the idea from my ZL1 that when had aftermarket headers added, it was extremely loud and the MF R X pipe made a huge difference.
I will follow up with more videos but here are some comparisons. In cabin noise is practically gone unless WOT and it's still very quiet and the noise is behind you rather than inside the cabin resonating. It sounds so much quieter than stock while cruising yet outside the car still sounds beastly. There is practically no drone compare do before. The noise now is much more deeper and refined compared to any other system I've heard. Hard to explain. PN Magnaflow 11386 Stainless Steel 2.5" Oval Muffler - Fabrication had to be done to go 3" OEM piping to 2.5" and back out or use a 2.5 to 3" adapter. So far no performance issues. MCarsFan drove my car yesterday and fell in love. Catless DP | Muffler Delete | Magnaflow Resonated X Pipe Catless DP | Muffler Delete OEM Down Pipes | Turner Muffler Delete
11-22-2015, 11:57 AM | #2 |
814
Rep 2,816
Another run I did. I need some rev and WOT.
jairomvp182515.50 |
11-22-2015, 12:29 PM | #3 |
814
Rep 2,816
Pictures showing stock vs Magnaflow
Ickdeep5727.00 |
11-22-2015, 12:36 PM | #5 |
814
Rep 2,816
Cold starts are still loud but no longer high pitched. Just a deep rumble
11-22-2015, 02:13 PM | #6 |
Rep 6,075
Off topic but , Is your License Plate referring to your previous car (AMG?) or you are humiliating AMG drivers? LOL
11-22-2015, 02:27 PM | #7 | |
814
Rep 2,816
11-22-2015, 05:21 PM | #9 | |
814
Rep 2,816
11-22-2015, 05:54 PM | #11 | |
814
Rep 2,816
11-22-2015, 07:08 PM | #12 |
Rep 84
Sounds like you have it dialed in. Well done. Now if we could just code out that cold start!
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
11-23-2015, 02:32 PM | #15 | |
Rep 1,250
Drives: 20' X3M CP
To get rid of the raspy sound. My cold start is gone (Thank god) tuned out! Only draw back is I'll ruin my LXR mid-pipe for resell Value. But I rather fix the sound and make it perfect as possible. BTW I don't hear your waste gate rattle
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
11-23-2015, 04:20 PM | #16 | |
814
Rep 2,816
I added the P/N to the first post. As for waste gate rattle, it is definitely still there but I agree it isn't as loud as it used to be. Used to be very loud since I have intakes, catless DP, and straight pipes.
11-23-2015, 04:32 PM | #17 | |
Rep 1,250
Drives: 20' X3M CP
I noticed mine gets quieter every week.
11-24-2015, 12:58 PM | #18 |
Rep 978
Liking It
Car sounds great, good work. I have actually had this same thought in my head for some time. The only difference is that I was thinking that a 3 X 3 Resonator would work better. I have the same thing in a larger Magnaflow setup. Now I am going to get under there and see if it works. Thanks.
2021 M340i
11-24-2015, 01:38 PM | #19 | |
814
Rep 2,816
The stock resonators are an issue and I recommend anyone doing muffler deletes or exhaust system to change them out to an aftermarket setup or delete. It has a high pitched raspiness to it.
11-24-2015, 02:48 PM | #20 |
Rep 978
Resonators
If is not too much and you haven't thrown away the stock resonators; what does the baffle inside look like? Any way you can take a pic of the inside? Thanks.
2021 M340i
11-24-2015, 04:28 PM | #21 | |
814
Rep 2,816
12-11-2015, 09:17 PM | #22 |
Rep 292
Drives: 17 M2 - 14 M5
Interested in doing this myself. How does this effect back pressure? Loss of perfromace?
