      08-30-2016, 02:55 PM   #1
Edmguy11
Drives: 2013 BMW F10 M5
CEL and BMS Intake loose
Folks, looking for some feedback here..
Today at work I noticed my CEL was on. My car is a 2013 BMW M5 with a BMS Stage 1 installed, along with BMS intake & charge pipes.
My initial thought when I seen the CEL was that it had something to do with the start/stop feature which stopped working recently.
However upon popping my hood I noticed my BMS intake came loose. I am assuming the terrible installers I was using didn't install the pipe clamp tight enough causing it to eventually go loose.
Safe to say this caused my CEL?
Unfortunately with BMS stage 1 I cant read CEL codes.
Either way I will likely be disabling the BMS Stage 1 and bringing my car into the dealership to be looked at.
      08-30-2016, 05:36 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Just got to an autozone or pick up a cheap 16 handheld and read/reset the codes
      08-30-2016, 07:48 PM   #3
Edmguy11
Thanks guy, Will Do.
CEL cleared once I fixed the issue with the intake.
      08-30-2016, 09:27 PM   #4
13M5F10
13M5F10's Avatar
I picked up the PLX 2 wifi dongle and used the free torque app to read and clear. Also reads a ton of data
      09-04-2016, 06:27 AM   #5
ur20v
would definetly give you a code (CEL)- you are getting unmetered air after the MAP sensor.
