      09-08-2016, 11:19 PM   #1
wheelpro
wheelpro's Avatar
Egypt
176
Drives: M5,F10,JB4,DP,CP,METH,SSP
Unhappy My Clutches Toasted ???
hi
all
i want help
my car f10 m5 s65 , tuned jb4 , meth , dp,cp,intake
i just open map 8 only 2 times
after that , i found transmission fault , and smell oil burning
, i read my car i found clutch pressure too high , and Gearshift Rod 5-7,1-3
what can i do ?
only want to change clutches , or my dct broken ,???
i read m about ssp, and dodson clutches
i saw price very expensive
which is better if i only need to change clutches ?
and any one know some one can give me good deal with fast shipping ?
i feel i am stuck
thanks god
      09-09-2016, 12:05 AM   #2
ur20v
http://www.sspperformance.com/bmw-dc...n-package.html
These guys seem to be the prefered supplier of upgraded clutches on f10 m5's. Lots of threads on this.
If you burnt your clutches and oil which is VERY likely on map 8 (anything over 22psi) you will get all sorts of errors- upgrade the clutch and flush the fluid then replace the filter- all avalilable from SSP.
      09-09-2016, 12:16 AM   #3
wheelpro
wheelpro's Avatar
Egypt
176
it cost more than 4000$ ????
why i need basket ?
i think i need oil filter , clutches, oil only
      09-09-2016, 12:27 AM   #4
allmotor_2000
1092
Drives: 2018 RS3, 991 Turbo
If you got the Rod 5-7 error it's more than the clutch. Read my DCT build thread...
Oil burning isn't the Trans - check your turbos as well. Did you overboost?
      09-09-2016, 09:00 AM   #5
wheelpro
wheelpro's Avatar
Egypt
176
boost set to 25 psi fail safe
and oil burning from trans , i smell clutches burning ,
and now car cant move ,
i read my trans , fault
1- clutch pressure too high
2- gear rod 5-7
      09-09-2016, 09:49 AM   #6
allmotor_2000
1092
Time to upgrade the clutches and rebuild the Trans I suppose
      09-09-2016, 11:51 AM   #7
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Sounds like you smoked the clutch and it is still stuck in gear. The steel plates are more than likely warped causing the clutch not to be able to retract.
SSP
      09-09-2016, 06:34 PM   #8
wheelpro
wheelpro's Avatar
Egypt
176
SSP
i will post pics after 1 hour for clutches
      09-10-2016, 10:32 AM   #9
Eddybro
Eddybro's Avatar
553
Drives: Melbourne e90 and SG e92
Originally Posted by wheelpro
hi
all
i want help
what can i do ?
i feel i am stuck
thanks god
Sorry to hear about this bro. Let us know when you figure out what your gonna do. I'm sure a lot of people are going to run into this issue considering they are running similar setups.. I'm sure running meth can make massive power gains, but at what costs. Also over boosting is another issue. Best to play it safe with a conservative tune, unless you got 10k stashed away for new clutches. With that said anytime you mod, gotta make sure you got deep pockets. Keep us updated.
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp
      09-10-2016, 11:27 AM   #10
wheelpro
wheelpro's Avatar
Egypt
176
thanks bro
      09-10-2016, 11:43 AM   #11
wheelpro
wheelpro's Avatar
Egypt
176
we open gearbox, i found clutch toasted ,
i am trying to upload pics
i changed clutches but used clutch from another gearbox , good condition
i test car
but i found fault code too
and car going shift only to 1-3-5-7
fault
1, clutch 2 comparison pressure too high
2, gearshift rod 5-7
i dont know what can i do ?
and on diagnostic , when i test plan with gearshift rod , autologic tools check function for all clutches from 1-7 and R
all ok
but car still transmission fault
      09-10-2016, 12:15 PM   #12
boots
Curve Thrasher
boots's Avatar
624
Did you do a stack up old vrs new and did you put the computer on the car to sync your new clutch system
      09-10-2016, 12:27 PM   #13
allmotor_2000
1092
Maybe Kris can chime in - possibly other sensors are damaged not just the mechanical items
      09-10-2016, 01:12 PM   #14
boots
Curve Thrasher
boots's Avatar
624
Yea sounds like a hot mess
TTV8M126.00
      09-10-2016, 07:01 PM   #15
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
When you put another clutch in the car, the adaptation procedure needs to be done. The old codes will not go away until this procedure is done. The car will not drive and function correctly.
SSP
      09-12-2016, 10:23 PM   #16
wheelpro
wheelpro's Avatar
Egypt
176
i made calibration for clutches and its work correctly
and i ordered ssp clutches , waiting it
      09-13-2016, 04:15 AM   #17
ur20v
Great news.
Let everyone know how you go with the install of the SSP clutch and first impressions on driving.
      09-13-2016, 05:34 PM   #18
wheelpro
wheelpro's Avatar
Egypt
176
Great news.
i will may be next week now its shipped
      09-13-2016, 06:34 PM   #19
ARC550
+1 I get my SSP Clutch this week! : SSPKris is D-Man!
P.s Kris, I'm the one that called that has DME working on car. I called yesterday about break in and shipping etc for M6.
      09-13-2016, 11:12 PM   #20
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Yes I remember. Awesome to speak with you about your build. Its great that the customers call themselves and ask questions. We take the time to explain this transmission in detail to our customers and dealers.
SSP
      09-13-2016, 11:16 PM   #21
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Thank you for the business. Your clutch and filter were expedited to you via fedex. I just checked the tracking for you and your parts were in France.
SSP
      09-14-2016, 08:07 PM   #22
wheelpro
wheelpro's Avatar
Egypt
176
Thumbs up
SSP
thanks for your care
