03-25-2019, 03:12 PM | #1 |
Rep 294
Origional Injectors - Highest Mileage
Who has a lot of mileage on their original injectors out there?
Curious if I should replace might at a given time or wait for symptoms to appear. |
03-26-2019, 04:10 AM | #3 |
Drift Instructor @ BMW Club UAE
311
Rep 433
Drives: BMW F10 M5
Replaced them at 85,000km
No fault at the time, but just had the job done
F10 M5 - AlpineWhite/SakhirOrange[DCT](Current)
F16 X6 - SparklingStorm/CognacBlack (Current) Follow me on Instagram (Click) |
03-26-2019, 04:41 AM | #4 |
Rep 19,971
Consider replacing around 66k miles at 33k now, a stuck open injector can spell the end of an engine.
calicolorado165.00 |
03-26-2019, 06:25 AM | #5 |
Rep 298
Are they covered under the Warranty? Just out of curiosity - what do they cost? (apart from an engine - worst case....).
2015 M5 CP Blue
[SIGPIC] Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 > |
03-26-2019, 07:16 AM | #6 | |
311
Rep 433
Drives: BMW F10 M5
As far as I know each injector costs something like 280$
schrickm575.50 carlitosgomesm5225.50 |
03-26-2019, 12:38 PM | #8 |
Rep 414
I called bmw on this and they said that the LCI m5s injectors are not covered under that warranty. I think they are the same parts though so I can't imagine what they did to fix the known problem.
2015 f10 M5
03-26-2019, 01:08 PM | #10 |
Rep 294
I know for certain that 2014+ have different part numbers and are a newer revision which is part of the reason why 2013 are less desirable - but I'm curious if the failures on 2014+ are actually lower
03-26-2019, 01:57 PM | #12 |
311
Rep 433
Drives: BMW F10 M5
Yes, the LCI models received upgraded HPFP and Injectors. they basically can stand a stage 2 tune easily.
Jasoneo539.00 |
03-26-2019, 01:59 PM | #13 |
Rep 1,073
Not a recall, just an extension of the warranty. They wont do anything unless a problem arises with the injectors. I have seen a post on Facebook where the poster claimed the failed injector blew his motor and BMW wouldn't cover anything. He didn't go into further detail but turns out he was also tuned so that may have played a role in BMW denying the warranty work.
03-26-2019, 02:48 PM | #14 |
Rep 19,971
US injectors are probably different to UK spec, here they have to run on 98 RON minimum,I use 99RON and can confirm UK cars have in line replaceable fuel filter under the car which is not there on US cars.Some have said it's in the fuel tank.
KurtsM547.00 |
03-26-2019, 03:27 PM | #16 |
Rep 19,971
03-27-2019, 04:41 AM | #19 |
Rep 19,971
From what I've read it happens in a moment, rough running.Best to stop and switch off quickly wait a few minutes and try starting again.
03-27-2019, 07:52 AM | #20 |
Rep 606
59k miles on my presumably original 2013 injectors. I'd like to get mine replaced under the extended warranty but as mentioned above, they won't do anything unless you have a code/problem. Even then, I'm not sure they would replace all of them under warranty. Probably just the one that the code is for.
03-27-2019, 08:07 AM | #21 |
Rep 108
Drives: 2015 BMW M5
I'm just getting back into a BMW having owned two previous, (E39 M5 and E90 335d,) but having owned a couple Z06 Corvettes in between, I came across and really thought the Red Line SI-1 Complete Fuel System cleaner did a good job helping to keep the fuel injectors nice and clean. I buy it by the case off Amazon and split it with my Dad.
A full bottle treats 20g but I usually only do about 1/3 to 1/2 a bottle every third fill up as preventative maintenance and peace of mind. I just took delivery of my new-to-me 2015 M5 this last weekend so I dumped in an entire bottle when I filled up the tank with Costco 93 as the vehicle had been sitting outside at a dealer in MN since February. I know BMW says you don't need to add anything, and I would not add 95% of the stuff on the shelf out there, but I've read some really good reviews on this in the Corvette community and I know it's doing nothing but good in my motor. https://www.redlineoil.com/si-1-comp...system-cleaner
