08-09-2022, 01:04 PM | #1 |
Rep 7
M5 Comp stalling when setting off HELP!
Afternoon all, new here to the group. Had my M5 since last April 2021
It has always had a problem where it stalls when setting off and accompanied by an error on bank 1 and 2 that says air to fuel mixture too lean. So far it has had brand new injectors, a fuel pump, new O2 sensors new MAF new spark plugs 1 new coil pack replacement ECUs with a fresh flash to factory incase it was ever previously mapped. I even removed the cats as one of the mechanics suggested they may be degraded. Car has full service history I am currently at a total loss as to what to do with it. Anyone ever experienced anything like this? Or possible solutions. I'm fairly certain everything that could cause the fuel mixture error has been replaced. Currently feel like driving it into a wall. It drives absolutely faultlessly apart from the stalling when you are setting off. It doesn't do it when cold when the revs are higher only when warm and only when setting off. Apart from that no misfires, errors or anything else. The oil smells strongly of petrol which I put down to the injectors but they were all replaced. Any pointers would be much appreciated. Last edited by KillerM3; 08-09-2022 at 01:27 PM.. |
08-09-2022, 07:22 PM | #3 |
Rep 7
It's on 65000 miles. When I bought it it was standard but when we changed the ECUs we noticed the old ones had been tampered with. Everything appears to be standard though so not sure. There is a receipt for warranty work to the cylinder heads a couple of years ago and it had a BMW warranty til 2020 a year before I bought it.
08-10-2022, 05:02 AM | #4 |
Rep 19,973
It's had new EU6 injectors and you are still smelling fuel in the oil, who changed the injectors.. I always ask for the old parts (like spark plugs) back and I wouldn't use the car anymore if fuel is going into oil. I suggest an oil change as soon as, oil is getting diluted with petrol mix.
08-11-2022, 02:53 PM | #5 |
Rep 7
Yes I have the old injectors and it's had 2 oil changes in the last 1500 miles. Apparently one of the old injectors failed but I changed the whole set. I can't figure out where else fuel could be mixing with oil. If a cylinder was leaking I'm sure it would be running rough in general.
08-12-2022, 03:02 AM | #6 |
Rep 19,973
There's only one way fuel can be getting into oil and that's through an injector, I can only think you may have a faulty new injector. Did BMW change them? They have two year warranty on all their new parts they fit.
danielgmanm691.50 |
08-15-2022, 04:16 PM | #7 | |
Rep 280
Could be a DCT issue as well |
08-17-2022, 01:54 PM | #8 |
Rep 7
No but they were original BMW equipment. I wonder if it's vanos related or whatever iteration of it the F10 has.
I did switch the Mafs and replace one. Wouldn't know where to start with the dct. Doesn't have any errors and appears to go through al the gears perfectly. |
08-17-2022, 02:01 PM | #9 |
Rep 7
Tags |
engine cuts out, f10 m5 |
