06-18-2023, 02:14 PM | #1 |
Rep 92
VANOS issue? NEED HELP
Hi guys, my car is stage 2 tuned with eventuri intakes vrsf catless downpipes and plugs coils injectors all new. Car was driving fine. I had a nice WOT run in it. Post which I was cruising around and i got a drivetrain error. Car started stuttering violently & misfiring too. The check engine light flashed too. I scanned the car at the same time & i got these codes. Post which i shut the car & restarted - still the same. I switched off the car & popped the hood open and could hear a ticking noise from the oil cap with the engine NOT running. Attaching the video & codes too. Car has only 18k miles..
https://youtube.com/shorts/GrQ_Xu68IVg?feature=share video |
06-20-2023, 08:19 AM | #3 |
Rep 20,011
I'm stumped on that, sorry. The ticking could be coming from around the oil cap area below.
I hear that choo choo sound once only when engine is switched off, that being the fuel pump priming itself keeping the fuel pressure up, could it be going off all the time with yours? |
06-20-2023, 08:22 AM | #4 |
Rep 92
06-20-2023, 08:33 PM | #6 |
Rep 148
Drives: BMW's
Garage List 2020 G07 X7 [0.00]
2013 E70 X5 [0.00] 2003 E46 M3 [0.00] 2013 F10 M5 [0.00] 2009 E90 335ix [0.00] 2009 E90 M3 [0.00] |
Seeing as all misfires are on one bank I'd be curious about rail pressure as well. Ive seen plenty of high pressure fuel pump failures but typically with faults. (They do have a 10 yr 120k mile extension) Unfortunately could certainly be a valvetronic issue as well. As VANOS and Valvetronic are two completely independent systems one would not effect the other.
06-21-2023, 12:56 AM | #7 | |
Rep 92
07-13-2023, 05:11 AM | #8 |
Rep 92
UPDATE - Hi guys. I had a valvetronic motor failure. I installed new valvetronic motor, the car starts up & idles fine. But once it warms up, the same issue happens, it misfires & bank 1 shuts. Should i swap dme?
