      03-21-2024, 05:33 PM   #1
evodude
Drives: 2015 BMW M5
Rear Brake Pad Sensor Reset
Hello all,
I had the wear sensor warning on the dash, checked it on my Autophix OBD tool and it said rear pads. Pulled the pads and sure enough they were pretty low and the sensor itself (the part that touches the passenger side pad) was chipped/worn down pretty good. I replaced the pads and the sensor wire yesterday, but alas the warning light is still on inside the car. Scanned it again and the error code 480A12 is still there; which says "brake pad wear sensor, rear axle, replace brake pads".
I disengaged the 'workshop' mode on the OBD tool, verified that. Is there something else I need to do to get that darn warning light (and display on the center screen) off? The front pads look good, but I haven't pulled the left front wheel off to look at that sensor yet - I'd think if that one was triggered the Autophix would tell me to replace the fronts.
Thoughts?
Thanks!
      03-21-2024, 09:52 PM   #2
Rated M Roadster
Rated M Roadster's Avatar
162
Drives: F10 M5, i3, Z4M
Just reset the brake pad service indicator as you would an oil change indicator.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      03-28-2024, 05:12 PM   #3
evodude
Drives: 2015 BMW M5
Thanks. Did that. Didn’t work. Any other suggestions?
      04-06-2024, 10:58 PM   #4
M_Bimmer
M_Bimmer's Avatar
728
Drives: F02 B7, G12 B7, G07 XB7, 911
evodude, try and reset the your brake CBS w/o the e-brake engaged....
      04-06-2024, 11:42 PM   #5
Rated M Roadster
162
Could also be a faulty new sensor. Did you replace with OEM?
      Yesterday, 09:57 PM   #6
celicatoe46m3
Drives: E60 M5 & E46 M3
I had the problem where my sensor was some cheap aftermarket. I ended up replacing it with an oem one and it reset ok.
