01-30-2021, 04:44 PM | #1 |
Rep 577
Car bogging after catless downpipe install
Hey all,
I recently got my catless downpipes installed and put about 700 miles on the car. The problem is that whenever I accelerate hard and the rpms go past 5k, the car bogs, stutters, and won't go (sounds like 2 stepping). I am still on the stock tune with a check engine light throwing codes just for emissions. Is this happening because I don't have a tune? I am thinking that there isn't enough fuel being sent to compensate for the increased air flow. Let me know what you think, thanks! |
01-31-2021, 07:55 AM | #3 |
Rep 1,372
The car is probably making more power with the catless pipes and your coils and/or spark plugs can't keep up. I'd throw a fresh set of spark plugs in and see if that helps. If you tune the car, you'll definitely want to install a fresh set of plugs anyways to avoid misfires.
01-31-2021, 10:29 AM | #4 | |
Rep 577
02-02-2021, 09:10 AM | #5 |
Rep 359
You probably messed up one of the O2 sensors during the install.. if you've done everything correctly and none of the O2 sensors are damaged it should drive the same.
02-02-2021, 12:04 PM | #6 |
Rep 577
That might be the case. I was lazy and didn't disconnect them when removing and they probably got too twisted. Question is, do I just buy all 4? Looks like it's $400 in total from FCP Euro.
02-02-2021, 12:36 PM | #7 | |
Rep 1,372
Sounds like spark plugs are not the culprit if you just replaced them recently. |
02-02-2021, 03:56 PM | #8 | ||
Rep 577
In the video I watched the guy did the same and was fine. After reading some more, it sounds like these sensors are very fragile... I bought all four of them with overnight shipping and will see if it fixes the problem. |
02-03-2021, 04:20 PM | #10 |
Rep 577
Update: Installed all 4 new O2 sensors. Car runs smoother but still bogs intermittently after 4.5k rpms (same problem).
I have no idea what's wrong. Taking it to a performance BMW shop on Tuesday and will update again then. Weird thing is that I'm not getting any codes other than increased emissions. |
02-03-2021, 09:27 PM | #11 |
Fueled by Recycled Dinosaurs!
735
Rep 1,237
Drives: F06 M6
Are you using a factory air filter? If you are using a high flow filter with oil like K&N it could be dirty MAF's. Also, did you check to make sure the air intake tubes are lined up and sealed all the way around.
02-03-2021, 11:42 PM | #12 | |
Rep 577
I will take a look at it tomorrow during the day. Not having those sealed all the way around can cause something like this to happen? Thanks! |
02-04-2021, 02:40 AM | #13 | |
Rep 28
PCV hoses
I'm not so sure if this would cause the bogging of your car thou.. |
02-04-2021, 10:13 AM | #14 | ||
Rep 577
Something in the fuel system could have crapped out at the same time, but there's no codes. Just the increased emission codes. |
02-04-2021, 10:21 AM | #15 |
735
Rep 1,237
Drives: F06 M6
Those hose do become brittle and crack. An easy way to see if you have any pirated air entering the intake is to spray a little starter fluid around the intake tubes and pcv. hoses. It only takes a short burst and you'll hear the eng pickup a couple hundred rpms. I'd inspect the pcv hoses for sure if you moved them around.
02-04-2021, 10:28 AM | #16 |
735
Rep 1,237
Drives: F06 M6
Did you happen to notice if there was any oil build up or leaking around the pcv hose coupler?
02-04-2021, 10:39 AM | #17 |
735
Rep 1,237
Drives: F06 M6
Also, how many miles on the engine? Are you the original owner and if not do you know if the prev owner tuned the car?
02-04-2021, 11:23 AM | #18 | |
Rep 577
There definitely was oil in the pcv hose coupler, is that bad? 32k miles on the car and more than likely had downpipes and a tune before. |
02-04-2021, 11:39 AM | #19 | |
735
Rep 1,237
Drives: F06 M6
any time you get pirated/unmeasured air involved things are going to not go well. If the car had pipes and a tune previously then it could be coils. The reason I ask about the tune is if they left it tuned then you may need to go with a step or two colder plugs and gap them as the added air pressure could be preventing spark.
02-04-2021, 12:23 PM | #20 | ||
Rep 577
In regards to the car still being tuned, I don't believe so since it drives like stock and it has a check engine light from increased emissions. |
02-04-2021, 05:13 PM | #21 |
735
Rep 1,237
Drives: F06 M6
If this ends up being an injector(s) issue; I don't have the TSB/notice but BMW extended the warranty on injectors to approx 120k miles.
02-04-2021, 09:41 PM | #22 |
Rep 577
