08-23-2015, 05:46 PM | #1 |
Hide! My wife's coming!
814
Rep 2,816
Stock Boost Levels
Anyone know what the stock boots level is at WOT ?
08-24-2015, 01:47 PM | #2 |
814
Rep 2,816
58 views and no one has the answer
08-24-2015, 02:31 PM | #3 |
2157
Rep 1,846
Drives: Many, BMW.
Around 17.5/18 PSI (1.2 Bar)
08-24-2015, 03:43 PM | #4 |
Rep 643
Drives: BMW M5 F10
Garage List 2013 BMW M5 [0.00]
2011 Alpina B3S Bit ... [9.50] 2010 Alpina B3 Biturbo [10.00] 2009 Alpina B5S [10.00] |
Depends, 560HP cars run 15-16 psi, those with competition package run around 17.2-18 psi
PetrolFumes352.00 |
04-24-2016, 07:45 PM | #6 |
Rep 2,039
Found this and it contradicts the 15-16 psi quote. Under WOT or heavy load, max boost is apparently 1.5 bar or 22psi (the magic number that requires JB4/BCM, same number a lot of tuners can't go passed).
http://www.bimmerfest.com/forums/sho...d.php?t=842484 EDIT: the reason I brought this up was to see if we can read boost levels after a couple of runs on e-sys. Somehow when I submitted this post it didn't include the e-sys inquiry. Last edited by TheHouseWon; 04-24-2016 at 08:32 PM.. |
04-24-2016, 09:20 PM | #7 | |
Plenipotentiary
2614
Rep 3,046
04-24-2016, 10:04 PM | #8 | |
1092
Rep 1,968
The number is 22.7psi to be exact. |
PetrolFumes352.00 |
04-24-2016, 10:12 PM | #9 | |
Rep 2,039
How are tuners getting more than 22psi w/o jb4/bcm? |
04-24-2016, 11:11 PM | #10 | |
1092
Rep 1,968
2. JB4+BCM actually controls the wastegates directly to target any boost value. The DME believes it is at its max programmed value. You want to keep that delta small for fueling and other purposes |
04-25-2016, 09:03 AM | #11 |
Rep 3,834
http://f10.m5post.com/forums/showthread.php?t=548345
Actually, stock S63Tu's maximum pressure is 1.5 bar = 22psi. Unless you are referring to normal boost, then yes around 18psi.
08-21-2016, 04:51 AM | #12 |
Rep 412
Sorry but I don't understand, the boost with map 1 JB4 is 18psi and the sotck boost is 18 psi too? Do I miss something?
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
08-22-2016, 10:17 PM | #13 |
Rep 402
09-06-2016, 10:55 AM | #16 |
Rep 1,749
All modern bmw turbo cars,and,and almost any car maker adjusts boost based on temp, elevation and essential air density. It always strives to make target hp. On a cold day at sea level a stock car perhaps hits 14 max boost. A hot day at elevation a car may hit 18.
Jb4 stage 1 and similar Piffy backs tap into this window and therefore essentially will make a car see 18 boost even if its,cold and normally would be 15. A hot day you have less headroom |
FSociety3816.50 |
