| 03-22-2016, 11:54 PM | #1 |
Plenipotentiary
2600
Rep 3,045
In the past or recently. I have been doing a significant amount of coding, programming, and diagnostics, but I haven't made any changes to these systems that are acting up. The only other change was an update of connected drive.
- If I press the boot lid close button (not close and lock or convenience close) there is a single, short, high pitch beep that sounds. It's not the locking acoustic tone nor the convenience close buzzer tone. -if I unlock the car, lock the car, turn on the ignition, shut off the ignition, open or close either front doors, the Blind Spot Warning light in both mirrors flashes once. - Acoustic Confirmation Lock Tone unselects itself, seat memory disappears, and last position ASS won't stay after one lock. Once the car has gone to sleep, it reverts back. - I have one profile saved, it shows active and I use the same key every time. (the others are far away) - Battery shows good and no faults registered. |
| 03-23-2016, 11:36 AM | #2 |
Rep 799
Don't think the software in these cars is debugged properly. I had low tire pressure and my check engine light came on (only time it ever came on). I adjusted tire pressures and check engine light went away. I have no coding or mods on my car. Base car + competition package. Go figure!
With your mods, there is invariably something that is causing a glitch. What happens if you restore to default (no coding) condition?
2015 M5 Individual Moonstone Metallic / Special order Caramel/Black / Special order Walnut Honey Trim/ Comp Package / ED / Left the Stable :-(
2018 Volvo XC90 T6 POLESTAR 2018 AMG GT 2017 Fiat 500C Abarth |
| 03-23-2016, 12:27 PM | #3 | |
Plenipotentiary
2600
Rep 3,045
The only thing I've been working on for a few months now is GFHB for LED since the original and only known method doesn't fully enable the function. I added 5AP and 8S4 back in and double checked the FDL values. Did 3 ignition cycles with 20 mins between each then left it over night. The little oddities are still there. |
| Bookmarks |
