| 09-27-2016, 01:10 PM | #1 |
Rep 207
F10 M5 and F12/F13 M6 Front Brake Pads replacement
Hey guys
I just did a front brake job, trying to get rid of the squealing with aftermarket brake pads, lets hope it does help at least. ![]() This is what the brakes setup looks like after taking the rim off ![]() Remove the top and bottom pins, just tap it out as shown ![]() Remove the nut that is holding the caliper on (14mm) ![]() Compress the pads to remove the caliper/pads setup ![]() Once the caliper is out, remove the pads, clean the piston area, lube the contact points and install the new pads. Everything else is pretty much reverse of installation, its pretty easy! |
| 09-27-2016, 01:31 PM | #2 |
Hide! My wife's coming!
835
Rep 2,816
Nice DIY! Thanks for the info
| 10-23-2016, 07:09 AM | #4 |
Rep 10,187
| 01-25-2017, 07:50 PM | #5 |
![]() ![]() ![]() ![]() 308
Rep 605
Nice DIY. Much appreciated. I will add that Cool Carbon front pads, leaving rear stock, completely eliminated all brake squeal for me. And, much less dust. I also have not noticed any decline in pedal feel. Very happy I made the switch!
| 02-04-2018, 03:16 AM | #6 |
Rep 9
So you didnt swap out the rotor? Sorry photos dont show. I have 9mm front left and 11mm rear and it squeals like holy hell. BMW told me i dont NEED a brake job but only a brake job would fix the sound. Said i have a lip at the top of edge of the rotor and when the brakes get hot it is causing the noise. What pads did you use and think I should try just pads for now? |
gdavis34.50 |
| 02-04-2018, 11:22 AM | #7 |
Rep 605
Cool carbon pads on the front completely eliminated my brake noise. I left rear OEM. I also have a lip on the edge of my rotors, but I didn't change them, and have had no problems. Much less brake dust.
Looks like ECS stopped selling them for the F10 M5, but European auto source appears to sell them, both front and rear. |
| 02-26-2019, 04:54 PM | #11 | |
![]() ![]() ![]() 5135
Rep 11,911
Typically, you replace the sensors when you replace the pads.
22 Phytonic/Coffee X5 45e (Retired)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
| 08-22-2019, 08:58 AM | #12 |
Rep 2
| 05-27-2020, 07:03 PM | #15 |
![]() 65
Rep 226
Hello, I'm wandering if anyone has found a good DIY for taking the rotors off as well? I'm looking for a DIY similar to this one with the pics and instructions.
| 05-30-2020, 08:37 AM | #16 |
Rep 47
I haven’t taken the rotors off yet. But I’m sure it’s a basic design with two bolts holding the calipers. Once the calipers are off, you should be able to remove the rotors.
2015 M5 CP - Alpine White - My joy ride
2013 LS 460 - Pearl White - Wife's 2007 M5 - Black Sapphire - sold |
| 03-23-2021, 02:41 PM | #17 |
Rep 14
I just performed this service. The rotors are held on by two allen head screws. Very easy to do after you remove the caliper
| 08-13-2021, 11:37 AM | #18 |
Rep 1,331
Drives: AW 528 xdrive (AW 335i coupe s
Is there a specific way to do the rear ones, I'm being told the rear is complicated because of the hand brake supposedly there is a specific way for that.
M-tech front and rear bumpers /M3 style side skirts/gloss black painted roof/ black window trim/Matt black grill/35%tints/4"dimisaTips/CF splitters/M3 style trunk spoiler/VMR V70s/JB4/BMS dci/AMS FMIC/H&R sport with BMW performance shocks.Thanx Sal and he's crew@AutoCoutureMotoring |
| 08-13-2021, 08:08 PM | #19 |
Rep 658
there are some DIYs on YouTube. search with "BMW rear brake pads with electric parking brake" You don't necessarily need the software to retract the electric hand brake. You can do it manually once you remove the motor.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination ![]() Last edited by arucano; 08-13-2021 at 08:17 PM.. |
M5Rick90335.50 |
| 04-01-2025, 12:01 PM | #20 | |
![]() ![]() ![]() ![]() 90336
Rep 27,089
The kit of 4 pins and 4 springs is £19 delivered on ebay at the mo so won't break the bank. |
| 04-03-2025, 05:40 AM | #21 |
Rep 27,089
Here, but hurry just one left at this price..
https://www.ebay.co.uk/itm/335725586...3Avlp_homepage * Back in stock. Last edited by M5Rick; 08-05-2025 at 07:11 AM.. |
| 04-07-2025, 04:27 AM | #22 |
Rep 27,089
For some reason four expansion springs are in this kit when only two are needed of which I will gladly put the other two into my small spare parts store.
So after removing each front calliper and resting in on a block of wood the old springs are easy to punch out and the new ones went in fine with a tap then liberal application of the anti squeal paste on and inside the 6 pots and the four brake pad contact edges of the calliper after cleaning is important. When offering the calliper back up to the rotor, especially if the rotors are lipped like mine are, it's easier to have the inside pad installed first into the calliper then when lined up halfway in slip the outside pad in and move it up making sure the brake fluid line is not kinked and in the right position. When finished, with the brake fluid reservoir cap opened up half way press the brake pedal down all the way and up gently and the second press should give you a firm feel, then tighten the fluid reservoir cap back up. On the test run the clicking and squealing were not present anymore with gentle and emergency braking but if you fitted new pads also then they need to be run in gently to wear the pads into the discs first, I'm sure you know that bit. Oh and don't forget to secure the brake wear sensor firmly into the n/s pad and into its support on the brake line angling it away from the wheel rim. Last edited by M5Rick; 08-06-2025 at 03:45 AM.. |
| Bookmarks |
