      09-20-2017, 04:06 PM   #1
sqeezed
sqeezed's Avatar
Drives: BMW 2014 M5
Fault, Error help
Hi All,
Is there any serious issue here I'm blind with these error code.
I have already appointment with my dealer the car still under Factory and maintenance warranty.
I used Carly to read and diagnostic
BUILD-YEAR: 2014
MODEL: M5 (F10 LCI) Automatic engine recognition (702)
FAULTS: 12
ECUs: 41
1. Motor Control:
Central Gateway / zentrales Gateway:
- Fault: Faulty asleep 30B
- Code: 801C15
5. Instrumentation:
Central info display / Zentrales Display:
- ECU not present/no answer
Zentrales Info Display hinten rechts:
6. Light/Rain Control:
High beam / Fernlicht:
7. Heating / AC:
Aircon rear /Klima Heck:
8. Immobilizer System:
CAS:
- Fault: sorry, unknown DTC fault
- Code: 93076B
- Code: 93076C
10. Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung:
11. Sunroof / Roof:
Roof / Dach Funktionen:
- Fault: Lin sinus, communication error
- Code: DE8C5E
- Fault: Deactivation IRS and inclination sensor by customer function
- Code: 801A4A
12. Audio / Navigation / Communication:
Interior camera/Innenkamera:
Telephone:
Digital Satellite-Tuner USA:
Central control rear/ Zentrales Bedienelement hinten:
CD-Changer / Wechsler:
13. Seats:
Driver seat rear /Sitz Fahrer Heck:
Rear seat passenger/ Beifahrer Sitz hinten:
Driver seat /Sitz Fahrer Heck:
- Fault: A fan at least in alarm control air cushion seat
- Code: 8029B3
- Code: 802A1E
14. Systems:
Junction Box:
- Fault: Starting ability in danger - Ignition
- Code: 8020E6
Nightvision:
Tire pressure control / Reifendruck:
HDD des CIC:
16. Chassis:
Air suspension / Luftfederung:
Dynamic vertical / vertikale Dynamik:
17. Body:
Steering / Aktivlenkung :
Trailer / Anhaenger:
Fussraummodul /FRM:
- Fault: Welcome Light-repeat active
- Code: 800F92
Axle rear / Hinterachse :
Roller left /Aufroller Links :
Roller right /Aufroller Rechts :
Damper front left / Rad vorne links:
Damper front rechts / Rad vorne rechts:
Damper rear left / Rad hinten links:
Damper rear right / Rad hinten rechts:
18. Motor Control:
Power Module:
- Code: D9D411
Elektronische Fahrzeug-Immobilisierung:
- Code: DA1411
Car Communication Computer CCC:
- Fault: :The link status of the Ethernet Drivers Not Ok Ethernet connection Head Unit to Rse highly
- Code: B7F8AE
Thanks
      09-26-2017, 04:38 PM   #2
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
You have low battery or conection problem. New battery and erase fault codes. 👍
sqeezed99.50
      09-26-2017, 04:39 PM   #3
sqeezed
sqeezed's Avatar
Drives: BMW 2014 M5
Thanks a lot
      05-23-2021, 03:45 PM   #4
MBWORLDZ2019
Drives: BMW 535i
Originally Posted by sqeezed View Post
Thanks a lot
Just curious if you got the problem solved by replacing a new battery.
Recently I got the same problem with the central gateway module, my windshield wiper will automatically start moving, central lock , backup camera , trunk all malfunction. I don't know if its my junction box having issues or battery.
I also got code and more codes lol
801C15 - Faulty Falling asleep at 30B
801C20 - Central Fault memory full
Any help will be great. Oh by the way I don't have the M5, Mine is a 2011 535i
      06-17-2021, 07:04 PM   #5
sqeezed
sqeezed's Avatar
Drives: BMW 2014 M5
yes everything was solved after the battery
