      06-02-2018, 01:38 AM   #1
Dwaynos
Dwaynos's Avatar
Cold start removal
I have searched everywhere for a solid answer but found none.
To put it simply, my car is too loud on cold start, I live on a road with street parking only and all neighbours are in close proximity. I don't want to upset anyone and have my car damaged. My question is, is it safe to remove the cold start with the cats still fitted and everything else stock?
Thanks
      06-02-2018, 04:02 AM   #2
Craze
If a stock car upsets your neighbours then im sure the mere fact owning an m car would upset them also
      06-02-2018, 04:11 AM   #3
Dwaynos
Dwaynos's Avatar
I can imagine it does, I'm just trying to reduce any chances of having my car damaged. At the moment it's a bit obnoxious and echoes in the street. I don't mind it myself but I really don't want it damaging.
      06-02-2018, 09:38 AM   #4
Mkai0
Drives: M2,Civic Si,4Runner, Lex GX460
No damage done removing cold start. However, I suggest letting the car idle normally for the 30-60 seconds the cold start would do, and not driving the car hard until fully warmed up.
      06-02-2018, 12:07 PM   #5
Nikolov
The cold start's purpose is to warm up the cats faster, so they'll be more effective quicker. The engine itself doesn't benefit from the cold start, so it's safe to remove it.
      06-04-2018, 01:51 PM   #6
DTP1980
DTP1980's Avatar
Drives: M5 F10 LCI Monte Carlo Blue
Thanks
I think what needs to be made clear is what exactly the ‘cold start’ removal is. I am under the impression that it is some kind of air pump feature which forces air into the exhaust system, causing it to be louder, but fooling émission systems. If you want removal of this, that makes sense in an area in close proximity to neighbours, because our MOT doesn’t take into consideration cold start emissions.
If the system is in fact part of the automatic ‘choke’ system, which creates a richer air-fuel mix at cold, then this function should not be switched off in the U.K, as your car simply won’t start half the year.
      06-05-2018, 01:06 AM   #7
Nikolov
The cold start does create a richer air-fuel mix, but it’s to warm up the cats faster, as they’re not effective when cold. The car will not stall when cold with the cold start removed. It will still adjust RPMs accordingly, although it’s barely noticeable, even in the cold.
      06-11-2018, 10:19 PM   #8
manny1424
Drives: 2014 F10 M5 Comp
2005 M3  [0.00]
2014 F10 M5  [0.00]
2016 X5M  [0.00]
Does this mean that cars with downpipes and no cats have no purpose of for the cold start?
      06-12-2018, 12:02 AM   #9
Nikolov
Correct.
      10-20-2019, 04:44 AM   #10
clubcsl
clubcsl's Avatar
Drives: M3 CSL,M5 F10,M4 CS, Z4 M40i
2003 BMW M3 CSL  [0.00]
2020 BMW Z4 M40i  [0.00]
2019 BMW M4 CS  [0.00]
2012 BMW M5  [0.00]
Does anyone how to simply remove the cold start ?
thanks
www.clubcsl.com - I am a BMW Motorsport fan !
My youtube channel is here
      10-20-2019, 06:41 AM   #11
Dwaynos
Dwaynos's Avatar
thanks
Only way is via remap/ecu tune.
      10-21-2019, 06:01 AM   #12
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
We can remove it very easily.
The purpose of the cold start routine is to bring the cats to operating temperature. On cars with downpipes, we recommend removal.
Cold start enrichment and secondary air are two different functions, not necessarily to be defined together. Enrichment from the cold start sequence would be to meet target air fuel ratios, and is separate from the coolant temp based model for injection. On cars with a secondary air pump, additional fuel would be injected to offset an increase in air. With the function turned off, the resulting Mixtures when-cold will still be similar.
OneExtra798.00
94jedi839.50
Ickdeep5719.00
      11-25-2019, 12:21 AM   #13
OnlyfaM5
Drives: BMW M5
Listen to him ^^
      11-25-2019, 07:43 AM   #14
AddyDaddy
AddyDaddy's Avatar
Just put it right into gear and cold start is gone. Just sit and idle in D
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
      11-27-2019, 07:15 PM   #15
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
idle for 10 to 15 seconds on cold start to circulate oil throughout the engine and drive off gently until it warms up a bit.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      11-27-2019, 08:23 PM   #16
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Is a 30 to 60 second warm up on a non carb'd DI engine with thin oil necessary or even harmful? From my understanding needing an extended warm-up is a myth, but its something I would like to address directly and get schooled on. Does idling the car for long when its cold lead to more friction vs short idle with a light drive to bring everything up to temp more quickly mitigating friction?
Please correct me if i am wrong because I read recommendations of long warm up cycles and i read suggestions that they are redundant and dangerous. I don't think 30 - 60 seconds could be considered long but is 10 to 20 seconds more ideal in the long run.
Something worth discussing to see what the experts have to say not that i have anymore input lol.
      11-28-2019, 02:33 AM   #17
Craze
Id say 10-30 sec is fine then drive no more than 4k rpm till oil temp is up
      12-19-2019, 08:47 PM   #18
BeachM5nster
Drives: '14 M5
lol this thread is now rendered moot
-BPM is the only place that could rewrite the code in my car to allow me to finally fully disengage traction control, and the only place that even had any inkling about what my issue could have been.. (it was written to not allow full disengagement from the factory [intentionally])
oh and we deleted the cold start and added 100hp+tq
and other goodies
hands down best money ive spent on the M5 - tune and coding
lots of possibilities and BPM is in the know.. trust me
      03-06-2023, 09:51 PM   #19
DODGE®
Drives: e60 BMW 550i Sport
Hello friend!
What is the cost for cold start removal?
Can you also remove the maximum speed limiter?
Can this be done remotely?
My car is a 2008 specs e60 550i.
Thanks!
      03-22-2023, 12:11 PM   #20
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Please email us at info@bpmsport.com and we can quote you. We do support the E60 and F10 non Ms as well.
      03-25-2023, 10:38 AM   #21
MarcF10
MarcF10's Avatar
2018 BMW X5  [0.00]
Thanks
Hi there mate, I have a similar issue where I live but instead of removing anything I went the opposite way and installed a modded exhaust, downpipes and cold air intakes. I have also added a very good stereo.
My point is, haters gonna hate, so just live life the way you want to and don't bother with the curtain twitchers.
If at any point you would like to have the cold start removed, then your best bet is tuning shops like Velocity Tuning in Colchester, DMS in Southampton, Evolve in Milton Keynes..and so on. They do offer ready made tunes for our car over ecu flash and they can do cold start delete, speed limiter removals etc. I think it's possible to do these remotely too.
Hope that helps!
