| 07-07-2018, 03:02 PM | #1 |
![]() 124
Rep 1,094
Hardwire radar w add a fuse?
Looking to hardwire my radar. In the past w my e92 m3 I used an add a fuse which is plug and play and allows you to get power without tapping into any existing wires.
Has anyone done the same on the F10 and know which fuse can be safely tapped to provide acc power?
| 07-07-2018, 07:17 PM | #2 |
Rep 658
The easiest way is to use the switched power in the mirror. I have that setup in my M6. In the five I tapped into the sunroof supply in the overhead console. Just google it. There are several posts.
You can tap an ACC power supplied fuse without a problem
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination ![]() |
| 07-07-2018, 07:21 PM | #3 |
![]() 124
Rep 1,094
I just don’t want to tap a wire and impact the integrity of the wire. The add a fuse method involes no impact to existing wires.
| 07-08-2018, 08:08 AM | #5 |
Rep 269
I wired my V1 and my Waylens using Add-A-Fuse. Used fuse #48 in the glove box. Been reliable for years. Power is on/off with ignition.
@Darkshear on IG.
| 07-08-2018, 10:19 AM | #7 |
![]() 749
Rep 1,106
I'm installing a dash cam soon and was going to wire into the overhead console, I may go this route and just to the add a fuse. Thanks guys
| 07-08-2018, 04:27 PM | #8 |
Rep 658
Try this link for the "tapped".
https://www.bimmerfest.com/forums/sh...ight=valentine for the "mirror plugged" version, remove the cap on the windshield electronics and find the plug where you can insert the wires for the power and ground The brown/black wire in the top right position is the ground. The brown/green wire in the bottom middle position is the 12 V switched
bimmer5301.50 |
| Bookmarks |
