| 09-20-2018, 06:56 PM | #1 |
Rep 15
Can the B&O amplifier on a 2013 M5 be replaced?
Hello,
I was wondering if it is possible to simply replace the B&O amplifier with another one purchased from ebay. I am having issues with my sound system turning it's self off 3-5 seconds after the car is on. The dealer said they would need to replace the entire amplifier which was around $3,000, plus another 1000 in labor and that I cant just use a used one because it needs to be programmed (despite being the same model?). On a side note, has anyone had same issue as me? The sound works perfectly fine when the car is on stand by (engine off), but as soon as I turn the engine on, the sound cuts out after 3-5 seconds and it says "Warning no tones". |
| 09-28-2018, 08:03 PM | #3 |
Rep 1,263
Yes you can utilize a used one.
Yes it should be programmed and encoded. No it does not NEED to be programmed and encoded. $1000 to install and program is insane, it takes the better part of 30 minutes tops to exchange the amplifiers and programming/encoding is usually billed out around an hour. ISTA/P is more or less a unattended process. Start it and come back later. |
| 10-07-2018, 01:43 PM | #5 |
Rep 106
Damn stealerships!
2014 ///Ⓜ️6 ⚪️ Comp. Package
| Adv.1 5.2 Track Spec CS Series| Down Pipes | KW HAS | K&N Air Filters | Charcoal Filter Delete | RPI Air Scoops | 2012 RUBICON 🌐|||||||🌐on 4d's |
| 10-11-2018, 11:20 AM | #7 |
Rep 1,359
Sounds like a control issue rather than the among it works on standby. Worth paying a good auto electrician to look at it. Could be a simple fix where the dealer will just go straight to replacement parts.
| Bookmarks |
