      05-10-2019, 09:17 PM   #1
pcohen15
pcohen15's Avatar
385
Drives: 2013 F10 M5, Singapore Gray
BlendMount
I use a BlendMount for my radar detector and they gave me a link to pass along to friends that will give you 12.5% off their prices.
Here you go: http://blendmount.refr.cc/petercohen
Full disclosure: I get 10% of whatever you spend, but you still save the 12.5% and then you'll have a referral code, too!
Here's my Uniden R3 installed.
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
      05-12-2019, 10:04 AM   #2
black_F10M5
black_F10M5's Avatar
297
thanks for sharing, I may go this route as well
any tips for which pins/wires we should be using for the mirror tap?
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S
      05-12-2019, 11:49 AM   #3
pcohen15
pcohen15's Avatar
385
It was super-easy, but I can't recall which two. Search this forum and a few DIYs will come up, or Google or YouTube. I want to say Green for Ground and Yellow-Brown for Power, but please check it out on your own.
The clamshell cover on the mirror just pops right off and the connectors are right there.
      05-12-2019, 04:29 PM   #4
pcohen15
pcohen15's Avatar
385
Found the instructions that I followed. Power is brown and green, ground is black and brown.
https://www.2addicts.com/forums/showthread.php?t=998321
      06-16-2019, 09:26 PM   #5
black_F10M5
297
Just used your code
Thanks for the link and the info
      06-17-2019, 01:29 AM   #6
roscopeeco
Drives: 2016 BMW M5
I want to make sure I get the correct one. I put all my info in but nothing came up. Do you know the SKU of the one that you purchased. I have a 2016 M5 fwiw.
      06-17-2019, 02:46 AM   #7
pcohen15
pcohen15's Avatar
385
Just used your code
      06-17-2019, 02:51 AM   #8
pcohen15
pcohen15's Avatar
385
BNR2017 is what I have for my Uniden R3. my M5 is a 2013, but I doubt the mirror config changed between mine and yours since both are F10. Blendmount was always responsive on customer support, so give them a call if the online configurator isn't helping you.
      06-17-2019, 02:55 AM   #9
pcohen15
pcohen15's Avatar
385
Just used your code
Needle nose pliers will be your friend if you're doing the mirror tap
94jedi843.50
