      12-05-2022, 05:04 PM   #1
SpeedProtocol
SpeedProtocol's Avatar
Drives: '14 F10 M5 - '21 F90 M5
Turbo coolant line leak, the lower connection!
I was going to fix the infamous turbo coolant leak (where the connectors at the top leak onto the turbos). You have to move the lines back a little to slip on the new rubber hose. I did the supply line and everything was fine. I went to move the return line and it was really stiff to move and then suddenly it was really easy to move. Then I heard the sound of running water.
All the way down by the water pump I could see coolant streaming out. The little bastard line had snapped off the connection at the end of the return line. You can see how the plastic barb broke off inside the rubber hose.
Now the bad part is that BMW doesn't sell just the connector. No no no, They only sell the entire assembly. PN: 11538092641
https://www.ecstuning.com/b-genuine-...e/11538092641/
100$ for a little broken connector.
Determined not to pay this I did some digging. Turns out this is a huge issue on F30s:
https://f30.bimmerpost.com/forums/sh....php?t=1547622
I'm about 99% sure that's the same connector. Ima cut that bitch off a 18$ hose instead. PN: 17128570061
I am amazed this isn't a bigger issue reported on these forums. Ive seen one other post about this. It seems like a high failure rate item and it really should be notated on some of these other threads that are about the upper connections.
-=SpeedProtocol=-
2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs
2021 M5 Motegi Red- GTHaus SGT Full Catback
M5Rick90338.50
BIMM5R10.00
      12-05-2022, 06:30 PM   #2
ECB
Drives: e39 M5, e46 M3,f10 M5, 997.1tt
Wow, that kinda sucks but at least you were in your garage instead of in rush hour traffic, etc. Now you have me thinking I should replace that preventively. Good luck with the fix!
      12-06-2022, 07:11 PM   #3
SpeedProtocol
wrong part. too small.
Regardless, i was able to repair my broken one. I will continue to search for the right fitting so I can replace it and update this thread.
      12-07-2022, 04:02 AM   #4
When I changed my top turbo coolant lines I sliced off the old ones length ways one at a time while holding the pipe in place knowing this part that broke is fragile.The new ones slid in easier while I held that pipe in place using a little vaseline.*Caution needed when doing this with sharp box knife.
      12-07-2022, 10:53 AM   #5
SpeedProtocol
Well I sure wish I knew that lol. Nobody has mentioned it that I have seen. I think my fix should hold for now though.
Its kinda scary now seeing this 90degree connector all over the intercoolers.
-=SpeedProtocol=-
      12-08-2022, 12:31 PM   #6
SpeedProtocol
that part is the pump for the turbo coolant. fortunately or unfortunately they are not known to last long. Mine is starting to hum so I will likely have to replace it before the connectors have a chance to break.
-=SpeedProtocol=-
      12-08-2022, 12:34 PM   #7
SpeedProtocol
https://f10.m5post.com/forums/showthread.php?t=1763599
another post with the same break
-=SpeedProtocol=-
      12-08-2022, 12:42 PM   #8
cortega
cortega's Avatar
39
Drives: 2014 F13 M6
Same thing here, had to buy the complete hose…
      12-08-2022, 03:23 PM   #9
Originally Posted by Droner View Post
It's a NORMA-RSS 90DEG connection. Could you tell me the part no. Droner then I can look it up on their site.
      12-08-2022, 04:01 PM   #10
SpeedProtocol
a clue! thats the one.
Damn I will have to see if I can somehow read off of it all the way down by the waterpump.
-=SpeedProtocol=-
      12-08-2022, 08:26 PM   #11
cortega
cortega's Avatar
39
Drives: 2014 F13 M6
Just checked the broken connector
PS3 NW12-90
PA66-GF30
      12-09-2022, 04:08 AM   #12
There's some on US ebay though with nw8,have a look at them, here's one.
https://www.ebay.co.uk/itm/263509733...Bk9SR6LbnsKeYQ
      12-09-2022, 04:28 AM   #13
This one with measurements.
https://www.ebay.co.uk/itm/362504955...75.c101224.m-1
D4T14.50
      12-09-2022, 09:51 AM   #14
SpeedProtocol
man you guys are awesome.
I just ordered a vacuum filler. This should give me a good excuse to do a full coolant flush/fill.
now if I can only find one of these to buy somewhere.....
-=SpeedProtocol=-
      07-05-2023, 11:15 PM   #15
SHO NUT
Drives: 2013 M5 Manual
A little more info on the Norma RSS NORMAQUICK PS3 part:
0702 8017 012 is the PS3 NW12 - 90º with the 6 mm bore we need and is made of PA66-GF30 (polyamide 6.6 with 30% glass fiber content)
courtesy of:
https://files.iq-parts.nl/NQ-PS3-702-8017-012.pdf
It's factory crimped onto the short piece of rubber hose, so you'd have to replace the rubber hose too, and the clamps. At that point, you should likely replace the other rubber hose also (pump end of the other pipe, as well as the hose kit at the turbos)
Supplier here:
https://www.iq-parts-shop.com/en/nor...-12-10-mm.html
(still working on a USA supplier)
Last edited by SHO NUT; 07-19-2023 at 11:40 AM.. Reason: Fixing numbers and references
SCD-1983678.50
cortega39.00
M5Rick90338.50
      07-07-2023, 09:59 AM   #16
SpeedProtocol
I just used the same hose and clamps I used to repair the top.
I would definitely recommend replacing all of them at the same time as well.
-=SpeedProtocol=-
      09-16-2023, 12:23 PM   #17
mike516
mike516's Avatar
Hi. This just happened to me too. How do I get the connector off at the bottom? Not a lot of space to work with. Is it easy to just pull it off and put the new connector on?
      09-18-2023, 09:23 AM   #18
SpeedProtocol
You need to use a pick to pull out the metal clip and then it should slide straight off.
-=SpeedProtocol=-
mike516121.50
M5Rick90338.50
      12-22-2024, 06:26 AM   #19
Ok we know it needs to be an NW12-90 degrees, with 6mm inner bore and 10mm outer.
my 4 upper turbo hoses and covers look like a dogs dinner though not leaking and going to change them for an acceptable set up with decent covers with the kit I have but want this bottom NW12,90 degrees, PA66 GF30 connector at the bottom in case it breaks while I'm doing it. There are some crazy price of this with same part no advertised but the wrong one from someone in Colorado for £248 ???. so we need to get the specs and measurements right.
I'm ordering it from NL (Holland) with the right specs for 17 euros (plus post.
Here's the wrong one not with NW12 on it !
https://www.ebay.co.uk/itm/186532479...Bk9SR5zzneT9ZA
      12-22-2024, 04:44 PM   #20
SpeedProtocol
I didn't find the connector. My fix is still holding.
-=SpeedProtocol=-
      03-28-2025, 02:03 PM   #21
ProjektAutoScott
ProjektAutoScott's Avatar
121
Drives: 2021 M340i
I am selling these now if anyone needs the connector. I have the OE Norma 90 degree used on this hose. Message me if you need one. Expect to pay about $40-50. They were such a PITA to hunt down and order in bulk, I am not interested in selling them for any less. I also can't find any other vendor for them in the United States.
I guess the combination of going from the larger coolant nipple to a 90 degree, then to a reduced sized barbed fitting makes these rare and unusual. There seems to be no alternative unless you want to rig up a bunch of questionable hose adapters to make it work.
M5Rick90338.50
BIMM5R10.00
      03-01-2026, 07:50 AM   #22
Sundayjumper
Drives: BMW F10 M5
Hi, new member, new owner and I have just run into this exact problem 🤣
Is the same size used anywhere else on the car ? I'm in the UK so not a massive problem ordering from NL but postage is still quite expensive for one part so would be worth ordering myself several.
